FRIGIDAIRE Refrigerator water dripping on top shelf
ratan
Jan 7, 2010
16
I have a Frigidaire refrigidaire (4 years old). There is little water dripping on the top shelf from the cold air flow vent. Can someone help me to diagnose the problem?
Water dripping
MY parents refrigerator started doing this a month ago. I took off the floor of the freezer and found and ice build up. 20 minutes with a hair dryer and towel and the problem was solved (hopefully for another 4 years) Jeb
Thank you everyone for your suggestions with diagnosis. I will try them. Hopefully it will resolve the problem. I will let you all know.
Defrost Drain Line
Whether you have a side-by-side, top freezer or bottom freezer model, the drain line will be in the same place: at the bottom rear of the freezer section. Some models may require removing a panel to get to it. I think most modern types will have panels that just pop off. Older types may have panels secured with screws.
