frigidaire spin tube dishwasher pics
a couple days ago it
also had a small leak on top around this inlet for the top sprayer but tonite it is not leaking in this area. maybe that top gasket just needed to get moistened up again and pliable after years of non use.
i did tighten up the wire twistie a tad with pliers, that may have helped also. but i really think it was leaking around that gasket too. oh well, no leaks now!
it's a lot of fun to
run it and listen to it! it has a very quiet whooshing sound and very distictive drain solonoid sound.
the spin tube itself seems to fly around it's post when i open the door and peek at it.
timer escapement increments are one minute each. it has an 8 minute first wash and a 4 minute final rinse. i'm gonna time a complete cycle here in the next day or so.
it has several water purges where the water enters tub while drain solnoid and motor are on.
rinses seem to be about one minute except for final rinse.
but it is a pain to load!
anything like a pan or bowl has to go in the top rack to be hit by the spray! all you can put in bottom rack are pl;ates and saucers or other flat surface dishes!
this would not be a machine i could ever use on a daily basis as most of my stuff is bowls, pans, cups etc. i ran out of room really quick in that top rack.
but i will say thateverything came out clean.
regardless, it's the most unique dishwasher i have ever had with that spray tube substituting for a bottom spray arm. this machine and the old style impeller machines make up a very important part of dishwasher history!
i'm very glad i was able to get it and am very glad i was able to fix it up with no leaks! and as said it is a lot of fun to play with!!!
Peter, there is a awy to put some stuff in the bottom rack so that bowls and pans get hit by the spray. See Dishwashercrazy's 1955/1956 manual for some ideas for that.  As to how good it cleans in that position is a guess on my part.  But you're right, it's not a machine for people like us and a daily driver.  A PITA big time.
