Front-Load Washers: A triumphant return and one still among the missing.
Looking at webpage linked above
It does appear there are two models; left and right hinged door.
Still no heater and cannot understand why for the life of me Alliance keeps resisting. Have used their commercial/laundromat washers and suppose results were good enough. But then again wouldn't put really soiled/stained wash in those machines where one wanted a truly "hot" wash.
Current SQ FL Washers
The stand alone models are now coming with the silly left hinged door [ it is silly how a less convenient design wins out in a market place at times ] You can order them with the more convenient RH door if you want.
As to why no heater I think they feel that few people want one, They were available 10 years ago and I only know of ONE AW member that actually ordered one. [ there are also three of us that have them because we got a discontinued model that had it ] But for me I almost never use it.
With today's detergents there is simply little or no need to heat things to 140 F or higher Great cleaning can happen at 120 F or even lower temperatures, and even 190F does not sanitize or whiten as well as a little LCB.
John L.
John, I think the question is how do you get a 120f wash, when that’s the inlet water temp.
Here the tank is maintained at 140 but the water is tempered to 120f. If you apply that to a cold drum your never going to get close to 120. My understanding is that there is a push in the US to maintain tank temps at around 120as well.
My Miele’s are hot and cold fill, if I program a 140 wash, it primes the sump with cold and then filled exclusively with hot at 120. When the fill us finished the best temp I’ve been able to record is about 95f and then it heats to bring the temp back up.
How do you automatically get a hot wash at 120 if that’s the inlet temp and the target temp?
Cheers
Nathan
^^ Absolutely this, especially if your washer is a HE model, and is a distance away from the water heater.
The current push in the USA is strongly for below 120F on residential water heaters, especially for households with young children, due to the scalding risks of higher temperatures.
Example: https://www.mayoclinic.org/healthy-...ler-health/in-depth/child-safety/art-20044027
This is in contrast with the prior recommendations, to set water heaters to temperatures above 140F, to kill bacteria such as Legionella. I remember as a kid, families also routinely set their water heater temperatures quite high so that the last family member didn't have as cold of a shower in the morning.
Speed Queen!
On the website it displays a cycle named (Sanatize with Oxi) - I had assumed that meant they were adding the heater. If not I wonder what this cycle does. I checked the instruction manual and it is not updated to this newer model!
Can anyone add input?
I'm sorry but I don't buy it at all.  And I bet our European bretheren won't either.  WP's new lower-end models also feature Sanitize with Oxi.  Fortunately the higher end models still heater water to a reasonable temperature.  When I use my Sanitize temperature, I see significantly improved heavy food and other soil stains vs. hot water at 127 to 130 degrees.  All I use is Tide With Bleach powder.
I refuse to succumb to the cooler wash water temp pressure.
I wonder what the Allergy Rinse will be.  Maybe actually a warm water rinse and extra water.
*Oxi* means absolutely nothing
It is not a registered or otherwise legally controlled word that must imply anything. Thus whatever associations consumers place upon the word is largely from their own minds, and or whatever marketing departments dream up.
Cannot understand why even cheap Asian front loaders offer heaters in their front loaders, yet Alliance still refuses to do so.
Myself and many others loathe chlorine bleach, so please don't say that is an option.
Chlorine bleach is not an option for more delicate whites besides that, chlorine make things yellow in the end. I've tried it a few times, but I didn't like it at all. Oxygen bleach does nothing against dustmites, so you need hot water for those cooties. 140F at least preferably maintained for at temp for an hour. I'm glad every washer overhere has a heater.
Is it possible that "Sanitize With Oxi" is just another expression for "Tap Hot" but without interference with energy regulations ?
Have my doubts about its effectiveness but it is still better than just having a dumbed down "hot".
Suppose we might see this more often in the future.
Chlorine Bleach does not yellow clothing, and if you can't use CB a good clothes dryer easily gets hot enough and kills dust mites, heating a load of clothing and water with electricity to 140F and keeping it there for an hour uses a lot of power,
I dare say the majority of loads of clothing in Europe don't get this treatment, where as the majority of loads of clothing in North America get thrown in a dryer that easily kills dust mites.
John
"Chlorine Bleach does not yellow clothing...."
Oh yes it can.
Sodium hypochlorite bleaches outright attack spandex, Lycra, silk, wool, causing among other things yellowing.
For cotton and linen fabrics "chlorine" bleach can cause yellowing via formation of oxycellulose. This occurs when too strong a solution, and or at too high temperatures, and or chlorine bleach remains in textiles that are subsequently subjected to high heat (clothes dryer and or ironing). The reaction is a response to a tendering of the fabric which produces the yellow shade.
Fabrics treated with sodium hypochlorite bleaches also can yellow if exposed to ultraviolet light such as rays from sun.
Chlorine bleach is difficult to near impossible to rinse out of fabrics. Cotton and perhaps linen especially have an affinity for the substance. Hence in commercial/industrial laundries several rinses follow the "bleach" bath. Then a final sour/anti-chlor rinse to ensure all traces of bleach are removed.
OTOH the standard one rinse (most American top loaders) or even several in a front loader may not cut it. If you can still smell chlorine bleach on textiles, it still remains.
There is a reason why European laundries and households long have avoided "eau de Javel", chloride of lime, chlorine bleaches for laundry use. It harms textiles in the long run. Some situations have no choice, such as hospital/healthcare laundries who aren't using thermal disinfection methods. You do find chlorine bleach in say France and other parts of Europe, but in the household cleaning supply section, not laundry.
Majority of clothing
Though our household is different to many, things have changed over the last 10 or so years since heatpump dryers got quickly mainstream.
Since dryers got quick and efficent, those who do use their dryer use it basicly for everything.
But its is true that does barely ever get close to 140F.
However basicly any machine can happily wash at 140F for 30min to an hour and still use less then 30min of US vented dryer use for quite sizeable loads.
Probably even a boilwash would use less then 1 equivalent load in a US dryer.
But most laundry gets done at either 86F or 104F, yeah.
SQ FR7 and FF7 vs pre 2017 FL's?
How's the FRY and FFY vs 2017 and earlier SQ FL's? Is it a match for something like the AFNE9BSP113TW01?
The new SQ TL TR3/TR5/TR7 are very differenct than the 2017 and prior TL's and don't clean. What's the consensus on the FR7/FF7 do they clean and how different are they vs 2017 and prior FL's?
Sanitize with Oxi button annoys me. I prefer Biz and it's like those four lower remote buttons on my Roku I can't reprogram.
Sanitize with Oxi= Oxi + 120-degree water (from a water heater) + a special button. I do hot water + Biz + Soak and don't need a button with a product tie in.
[this post was last edited: 5/26/2019-16:42]
Have said this before
To sanitize a surface or something merely means to reduce harmful pathogens to levels not likely to cause illness. Washing one's hands is a way of sanitation. Merely washing laundry with detergent and water also sanitizes as it removes dirt, germs and whatever from fabrics, they then go down the drain with water. Still alive perhaps but never the less fabric is now "sanitary".
You need hot water temps at or > 140F or even better 160F to remotely really get at germ killing power. Adding oxygen bleach at 120F is likely better than nothing, but still believe this is more marketing hype than anything else.
