Fun with wringers
That looks like fun, Steve!   Do you enjoy your Speed Queen wringer?
When washing, do you hang the hose over the sink?  Does it get in your way?
I purchased a brand new Speed Queen from Lehman's Hardware around 1998 and used it for a few years.  It didn't have the pump feature and was "plagued" with an oil leak around the transmission.  This was one that was manufactured in Saudi Arabia.  I really liked the machine and the way it washed.  The wringer was extremely sensitive and popped open quite frequently.
Geoff,
Yes, I really like my Speed Queen, especially since the GE hydrowave is out of commission at the moment. The SQ does a great job. The hose hangs over the sink during washing and doesn't get in the way at all. I haven't had any issues with oil leaks. Mine dates from around 1980.
The Speed Queen DOES do a really good job; I know how impressed I was with the one that I had.  The wringer and transmission leak were my biggest problems.  I bought mine when Lehman's was just getting them shipped from Saudi Arabia and some of them had a lot of little issues.  The tension on my wringer wouldn't allow both rollers to be really "tight" against each other; there was about 1/8" gap when set.  I was so used to Maytag's tight rollers that I had a hard time getting used to the Speed Queen.  Lehman's was really nice about everything, however, and offered lots of suggestions to get it the way I wanted.  They even sent me a new set of rollers in case the ones I had were warped but that still didn't resolve the gap problem.  The next step would have been a brand new wringer head.
Lehman's even sent me a new transmission to resolve the leaking issue (for free!) and the transmission arrived with the main stem to hold it to the frame being bent over; I was disappointed (and so were they).  I tweaked it as much as I could and after about 5-6 years, I donated the machine to an auction for our local parish; it went for a few hundred dollars!
The machine I bought had the porcelain tub instead of stainless steel.  I had taken really good care of it.
The machines made by Speed Queen in Wisconsin were of excellent quality; your machine is truly a good demonstration of that!!  :-)
I have a 1950 Speed Queen that my mom's parents bought new, but didn't use for 6 years until the other Queen finally gave up the throne.  Even today, she runs like a top!
<span style="font-family: arial,helvetica,sans-serif;">Would  1950 be made by McGraw Edison or Barlow & Seelig? thanks alr2903</span>
Barlow & Seelig all the way!!!  Mine is sort of a BOL machine, it never had a drain hose.  You position it over your floor drain and pull out the knob that opens and closes the gravity drain.  Kind of different, but moving a washer full of water can be a bit of a PITA.  Mine also has the blue trim that they used before they switched to red in the mid-50's.
Sorry, no pics available, don't have a digital camera or scanner.  I need to really move into the 21st century. lol
Sensitive wringer also
I had a SQ probally 1970ish model and the wringer was very sensitive. I didn't have any problems with oil leaks and it washed great. But every time you tried to put anything thru the wringer of any thickness it would pop. This was very frustrating. I would hold the handle up to keep it running. I would love to get another one if there was a way to adjust it. I have noticed on alot of the videos that others seem to "take what ever they are given". I was starting to think it was just a problem with my machine but after reading your comments here wonder if its a common problem.
Thank you for the nice words
Hi, I noticed that you have a posting about the wringer washers that Lehman's carries. First of all @wringersteve, your video is hilarious we are planning to post that on our facebook page.
@geoffdelp sorry for the trouble that you experienced, thank you for the kind words about Lehman's though. We try very hard to ensure satisfaction.
@wetguymd, I hope you don't mind, I ran the problem that your experiencing by the fellow that does the work on our machines he had the following to say.
Most of these washers being talked about are older. There are many things to look at. The tension issue could be worn roller nylon bushings. If the roller shaft is run "dry" it will wear these bushings fast. It is important that the roller shafts are greased. (something not always done great at the factory) There is also a tension setting for the lower roller and that may need adjusted. The popping of the wringer is more than likely a worn crank lock tab. The "catch" on this is only around 3/16" to begin with and when it gets rounded edges, it will not hold when larger items are run through. This tab is not always "squared" from the factory and can have rounded edges from day one. Once this starts unlocking, it will continue to round the edge. I have also seen the bolts come loose that hold the catch and coupler sleeve together. This allows a partial catch on the lock tab. We no longer carry the washers with porcelain tubs, they are all now stainless steel. A much nicer tub that holds up much better. We have had almost no problems with transmissions leaking, it is important to keep the machine upright, as if they are laid on the side, they will leak. Most issues we have are with the wringer, which generally are an easy fix.
I sincerely hope this helps, if Lehman's can be of any assistance feel free to call us. Thank you.
http://www.lehmans.com
Imagine.....
Someone is still stocking, selling, and repairing wringer washers. Amazing. And now we know where to go.
Your video is a real tickler, Steve. Thanks.....but no bubble gums bubbles, please :->
