So this interesting machine was listed on Kijiji, and I bought it. I understand that Fust is store in Sweeden, so this must be the house brand washer.
The good the bad and the ugly:
Washer fills, Program timer works, Heater and Thermostat work!
Pump too weak to pump out, Motor not working...
When I first got it the motor worked for about 2 minutes, and then smoked and no longer works. Curiously, during what should be spin, if I manually spin the drum, the motor will turn, until it stops to reverse.
When I watch the pump spinning it seems to work OK, but when under load (with water) it tries and tries but can't pump.
Would be nice to get it going again. How many people in Canada have the luck to have a "real" top load H axis!
Guy
Guy
