G.E. Filter-Flo Questions. Have never seen one before and have chance to acquire two
mjg0619
Jul 25, 2013
162
Scranton, Pennsylvania
Hello everyone,
I have the opportunity to acquire two G.E. Filter Flo washing machines, but there's one fly in the ointment; they both leak.
The source of the leaks is unknown and I'm curious as to where the common spots on these machines are and how difficult it is to repair one.
To the best of my knowledge, they both run properly, they just don't quite hold water!
Pics are attached below. The avocado one looks near mint under the dirt.
That first washer was the exact model my mom bought in late 1978 or early 1979 after me getting my next model up GE in April 1978.
Not much to repairing these really. They were bad about leaking after 10+ years of use sometimes. The leaks were usually fixed with resealing around hoses or the boot between the inner tub and transmission, not a difficult fix. You just have to pop the top up and remove the inner tub to get to it all. Hard to tell exactly where it is leaking without seeing it full of water. I imagine they would both be worth getting. Especially if the only problem is a leak.
2 thumbs up
Had exact washer LOVED it. Cleans extremely well. First new washer I bought.
EX was in ( ashphalt) construction and all his clothes came out clean and fresh.
What a great find.. I've looked here for years and one hasn't surfaced. :(
OHHH, I would love these.
There are several scenarios that could cause leaking.  Some are easy fixes, others......
If the tub has rusted through ..... after nearly 40 years, that could be tricky.
Or it could be something simple like a hose leaking.
I grew up with the green model
My dad worked for Pay-N-Pak in the late 70's-the early 90's. Mom purchased that exact washer with the matching dryer but in almond. We had the set until the the early 90's then the washer went belly up and sent me to the laundromat and after the trip to the laundromat I went and bought her a new Whirlpool set.
I had a FF that only leaked near the top of the outer tub -- was caused by years of out-of-balance loads that the inner tub had rubbed a hole in the outer tub, so water would spill out of the hole during spin. Patched it up with epoxy and it never leaked again. (and also made sure I loaded the tub evenly to avoid any out-of-balance situations!)
Great machines. Enjoy!
I'm going to say it's smaller...though I'm not exactly sure. I have the "Large" capacity Filter Flo and going from the Kenmore 28102 at 4.5 cu ft, it's at least half the size...no sure about the "Extra Large" capacity FF's though.
Does anyone have the cu feet on the Filter Flo's? I have an old brochure but it doesn't say the capacity size. I had heard the Large was about 2.0 cu ft and the ExtraLarge was like 2.8 cu ft.... anyone know?
Common leak areas occur anywhere there are hoses and/or boots attaching to the tub. My '76 Dispensall had severe corosion at the base of the outer tub where hoses connected. It was actually a pretty easy fix though. Here are pics of the before and after repair I did. The washer is completely water tight now. Unfortunately I can't say the same for the tranny so in the corner it sits until I can tackle rebuilding and sealing that too.
