Mieles are 2.3-2.4cuft FLs.
But that's no apples to apples comparison, though.
I was talking about an EU top tear machine, which would take upwards of 2h, wash from cold to 104F, rinse thrice and spin at 1600rpm.
It has a seperate recirculation pump, a brushless motor etc.
And EU rated capacitys are so and so, rather unrealistic for the most part.
However, given that about a cuft of space is agitator in the TL and a TL needs more drum volume per load size, 14lbs is about the same load capacity you realisticly fit in a Miele.
A 10lbs load uses about 14gal for the same cycle and runs in the 2h ball park.
But the again, Miele can wash 10lbs, cold fill only (240V), with just about 1h at 104°F and 1600rpm, rinsed twice, with just 12gal in its QuickPowerWash cycle.
140°F isn't much longer either.
And that whole procedure dosen't even use 1kWh.
My comment wasn't meant as a direct comparison. Our machines ported 1:1 to the US would never satisfy customer needs.
My head shaking was more that such usages are still acceptable to some. I know that I too run cycles that use 20-30gal in our FL, but such cycles are for delicates, woolens or comforters and pillows, cycles that then rinse 4-5 times.
My daily wash loads use about 15gal for a 10lbs load that is washed and rinsed 4 times.
