Gas MT Neptune drying center Minneapolis CL
Does anyone know the construction of the control panel?  Are there mechanical switches at each button-spot like F&P panels?  I'm not going to peel my Neptune TL's panel apart to check.  :-)
Neptune drying cabinet control panel
It is a typical touch membrane type a control not easily repaired, they usually sell you the entire control panel at times you could get just the overlay membrane switch assembly which could be peeled off the old control panel and pressed into place.
The part has been NLA for a while you might be able to find a good used one somewhere.
It’s a neat product overall cheaply made as it came out of the Norge division of Maytag it was not up to the quality Standards of Maytag certainly not as good as the Neptune front load washer.
I installed a brand new one in my laundry room last year, I use it it works OK it’s kind of a cheap dryer though .
John L
