Gas or Electric?
Please forgive me if this is a repeat. I did not see it above.
An electric dryer is said to consume 2.5 KWH per load, IIRC.
(That would mean the element is "ON" about half the time..constantly on at first, and nearly constantly off at the end of the cycle. This is why the themostatic automatic-dry cycle controls function so well [where the timer advances only during the heat's "off" cycles]).
Gas is usually always cheaper than electric since it takes three units of gas to produce one unit of electricity. (Therefore using fossil fuels directly for heat requires one-third of the total energy.) Of course, areas with hydro-electirc generation may produce electricity much cheaper than gas and "healthier" to the environment than fuel-burning or nuclear generation.
Well, this aws a discussion at a party I attended Sat. Several local area residents observed their combined natural gas & electricity bills were more than an all-electric home's bill. The gas homeowners report their bills have doubled in the last two months and it's not even winter. They are "concerned" but they also know they can "bear" it very well.
There is frequently a discount in the rates for homes that are all-electric. Not sure if it makes the bill lower than a house that has and uses gas.
Certainly in this area the discount is prolly meant to make electric affordable for heating.
Using electric for heat in this area is good FOR THE UTILITY in that it tends to help balance the load/demand for electricity. As you know summer demand FAR exceeed winter demand in this area. During the summer, the utility must add diesel generators online to handle peak demands. These are expensive to run and to maintain when NOT running.
