kevin313
With the wealth of knowledge here, I'm hoping someone can help with this issue.
I've got a GE stove with an automatic Calrod burner. It is the only large burner on the cooktop - it also has a switch that allows the use of just the inner coils or all coils. The switch for the burner is the sliding type - from right to left...low to high.
This burner will just get lukewarm - barely hot enough to melt butter in a pan while set on high.
Any clues? Easy fix? Can it be converted to a regular burner?
I'll get some pictures of the stove up here in case that would help -any advice is deeply appreciated!
Thanks,
Kevin
Thanks,
Kevin
