GE - CL finds
Photo 2 above is my doing...
I'm sorry for inserting one photo above, that was for another stove…too funny, I just noticed.
Jeff - I agree. That is one of the cooler looking stoves that GE designed.
Vintage Mid Century GE Stove Range P7 Works Perfectly Like
photos are not so great!
AD: " No restoration needed, amazing condition.
GE P7
The first self cleaning oven, started in 1963.
Yellow green, faux wood trim. Brady Bunch vintage feel.
Very Clean, almost new modest use. Stored safely.
Beautiful chrome, new original broiler pan.
30" wide model # J 365001 HT
Made in Louisville NY USA embossed.
Serial # N 2424776
Model dials are different than picture.
Handsome dials, perfect for mid century feel home or vintage look.
Please bring hand truck and two strong people.
Item in basement, used only as a secondary for parties.
Working range and oven.
Appliance outlets on top, likely top model of its day."
http://nwct.craigslist.org/fuo/4812478569.html
I don't see how a fridge could "freeze up" if it was low on freon.
Thermostats were the weak link on GE's from this period.  I'd wager that's the problem, unless the seller doesn't realize that the freezer isn't frost free and requires periodic defrosting.
When the thermostat failed on my '57 top-mount, it wouldn't cycle off.  It just got colder and colder, and the serpentine coil in the refrigerator section developed a thick layer of frost instead of the thin glaze that forms when the cold control is operating properly.
If I were you, I'd go after a  GE Combination from 1959 or later with "Frost Guard" if it's going to be your daily driver.  From what I've read here in the past, defrosting those bottom freezers is a task that should be avoided.  Also, the articulated shelves on the Frost Guard models are a superior design to the revolving ones.  I think you'd be much happier with a fridge that looked like the turquoise one a few posts up.  It's worth the wait for one to come up for grabs in your area.
Washer and Dryer Combo - $249 (Taylors, SC)
" Well built, heavy duty washer and dryer set for $249. I am willing to deliver to the surrounding Greenville/ Pickens area for $50. This set runs perfectly and has been well maintained. Included in the purchase are the hoses and wires. No need to worry about having to replace an expensive computer board, the set has manual controls and is Y2K safe. The dryer dries clothes super fast and the washer gets the squeaky clean.
Brand:
General Electric (Made in the USA)
I will only respond to emails with phone numbers.
David "
http://greenville.craigslist.org/app/4810251224.html
Range in Reply #35:
Wow, has that seller got a few misconceptions!
The range is mid-1970s; the clues are the stainless trim on the outer edges of the cooktop, and the control knobs, which have stamped skirts, not the die-cast ones of earlier models.
The range is mid-MOL; it has P*7, a lighted cooktop and the desirable two-large/two-small burner configuration, but it does not have Sensi-Temp. The "yellow-green" color mentioned in the ad is Harvest.
$250 is a very high asking price for a fairly ordinary '70s GE in a hard-to-shift color.
GE in Reply #44:
That is to die for! Exactly the 40-incher I'd want, if I had room for one.
Don't get me wrong, a good 30-inch range is a great thing to have, but for those of us who grew up with the Big Kahuna, there's nothing like having all that cooktop real estate, plus two ovens.
This one looks to be complete and cared for.
Sigh!
Wrong Coast
I'd be all over that Pensacola fridge if it were near me.  Looks like the right size (smaller model) and door is hinged the way I need it.
Sorry, Phil:
But that 40-incher in Reply #55 is Harvest, not Yellow.
The easy way to tell Harvest from Yellow is to look at the edges of the oven door and the front of the storage drawer. On Harvest, these edges will be "shaded," meaning that an area at the edge will be sprayed with a slightly darker color than the middle of the panel.
On Yellow, no shading was done; it was a solid color.
thanks
Sandy - I appreciate the help. I kind of sort of in a way thought it was Harvest at first, but didn't catch the detail you mentioned. And I can't change the text until I upgrade as a member, so until then ( and I'll be doing that later next month), your correction works.
Onward! :-)
