GE cooktop and range hood w/ remote controls
I don't think I've seen one with knobs, I like the variable speed fan. I don't think I've ever seen a variable speed GE hood before. What kind of exhaust fan does this use, is it the typical 5 blade propeller, or a blower wheel type fan?
lol. "remote controls"
imagining controlling the stove with a VCR remote.
'hood mounted controls' might be a better description.
Still, this GE set is a rare one.
And awkward if you only need to replace one of the set.
It's like the 1960s GE 27" slide-in ranges that had a separate wall mounted control box. A friend had one and when she had to replace the stove in the mid 80s, GE no longer made that so got another 27" slide-in but had to leave the non-working control box so as to avoid a big gaping hole.
This could have dated to the mid'80s. I remember helping my mom spec her new kitchen in about 1985/6 at Swallen's in Cincinnati...this was a little esoteric from what she wanted--she ended up with a 33" Kitchenaid with a one of the large elements being a high-watt burner. Replaced a 33" Tappan/Youngstown from 1959 when the house was built with 7-detent knobs at the back of the cooktop. She was a little leery of Jenn-Air because of size...
Notice that neither the appliances, nor the booklet, say GE, but rather "A quality product of General Electric Company". This is because both GE and Hotpoint dealers were selling the same built-ins by this time. Swallen's was a Hotpoint dealer for many years, until GE decided to make Hotpoint a budget brand. Many dealers complained, so they also got access to the GE line in the late 80's.
At a yhard sale spotted a hood that had remote pushbuttons for a range top that went with it-the colored GE buttons-loved those from when I was a kid.Someone bought the hood and stove before me!
You can see why these are such a liability to install.
Unless there was a special duct going from the upper to the lower cabinet for that, what appears as a old style printer cable plug, how in the world would one get that in the wall?
It's a relic from the 60s when GE seem to engage in a number of experimental appliance designs.
I'd be curious to see what that connector looks like; I thought they were all hard wired.
I don't think installation would have been too much trouble; most stud bays give you 14.5" to work with and the openings at both ends would be hidden so no special care would really be required. Just punch a hole behind the hood and let gravity do the work as you snake the conduit in, do the same beneath the counter and Bob's your Uncle!
GE Remote Controlled CTs and Drop In Ranges
As Cory mentioned these were simple to install, The hood or wall control was hard wired to the electrical panel and then you just plugged in the cable to the range hood or wall control module.
I installed a 1965 unit in our 1965 mountain home about 35 years ago and it was easy and still works great.
These were anything but experimental GE built and sold tens of thousands of them.
Yes, plugging the modular plug into the other component was easy, it's the setting that set-up of having to make anme ambiguous hole in the wall that's the problem.
What if the wall is cinder block, or tiled? One would also be breaking a fire stop by making these holes that are right above a kitchen stove.
No other major appliance I know is such a convoluted install.
Just move the appliance in, plug it in, connect water or gas, vent line.
