About a year ago I was a member here, and you all helped me get my filter flo washer fixed. Not sure why but I couldn't access my previous account.
I finally got a matching (ish) dryer, and at first it needed some work. I replaced the timer and heater element with NOS parts, and it worked great for a few weeks, then the motor bearing failed. After a good bit of trouble getting the wiring correct on the new replacement motor, I finally have it and the motor is running as it should, but I have no heat!
Dryer is a DDE8508mal
I'm measuring 122v on each side of the main terminal bar at the back, I have continuity at the thermal switches on the heater element and the box behind it.
I'm not 100% sure on how to test the heating element, but grounding each side to the case gives me 122v, going from each side to center = 0v
I'm really at a loss here, and need this thing operational asap. Whatever list of things there is I can check and how, please let me know.
