GE GFW655SSV0WW Front-Load Washer & Matching Dryer
niclonnic
May 31, 2015
67
Bonney Lake, WA
This is our brand-new washer and dryer set; it replaced a low-end 8-year-old Frigidaire set that came with the house. That top-load washer was not the best; its long cycle times (1 to 1.5 hours), coupled with a lack of turnover, resulted in mediocre wash performance. And, to add insult to injury, the drain pump's plastic bracket broke, so puddles of water leaked onto the floor during operation. A new pump would have been over $200 to replace. Although the matching dryer worked very well, it took an equally long time to dry clothes (a "heavy duty" cycle took over 2 hours to dry towels).
So we used the circumstance to buy a whole new set. My dad did some research on a new set, and he ultimately settled on this GE front-loader (GFW655SSV0WW), along with its matching electric dryer (GFD65ESSV0WW). We ordered both appliances from Home Depot; they were running a Black Friday deal in which we would get $150 off the whole set.
Last Friday (12/6), the delivery guys arrived, installed the new set in our upstairs laundry room and hauled away the old Frigidaires. (Apparently, there was a dead bird in the dryer vent, as a side note.) We were instructed to run both the washer and dryer on the "quick wash" and "quick dry" cycles, twice, respectively, both to verify operation and presumably get rid of any residue from manufacturing.
Here are the hallmark features:
- SmartDispense stores up to 50 oz. of liquid detergent, which is then automatically dispensed depending on the load
- All-touch control panels, coupled with mechanical cycle selection dials
- Wi-Fi capable; can be controlled from anywhere with a smart device app
- Dryer Control via Bluetooth; if both appliances are stacked (ours are not), the dryer can be controlled right from the washer. It even auto-suggests the correct dryer cycle after a wash
- PowerSteam removes stains from loads in the washer; sanitizes and dewrinkles clothes in the dryer
- UltraFresh Vent System dries out the inside of the washer, so the door can be closed when not in use
- Microban protection throughout the washer
- HUGE capacity (5.0 cu. ft. for the washer, 7.8 cu. ft. for the dryer)
- Dryer features a "SensorDry" system, which senses the level of moisture in the clothes so they don't get overdried
First impressions:
- Exceptional cleaning! I can see why FL washers are the superior option. My faith in this style of washer has been restored.
- Mega capacity allows me to wash and dry bulky items, like a queen-sized comforter, with ease.
- Cycle times are more than reasonable (a "normal" wash cycle takes around 55 minutes).
- Noticeably quieter than the old set.
- Water level seems good, although I can't see any water during a cycle.
- Spin speeds are FAST; the washer wrings out a lot more water, so the clothes can spend a lot less time in the dryer. However, this results in vibration which shakes the whole upstairs.
- Dryer has a "folded" lint filter design, which has to be unfolded to remove lint.
- Both feature tinted windows and drum lights, which can be turned on during operation.
- GE SmartHQ app allows for the firmware on both appliances to be updated; it also provides notifications as soon as laundry is done washing and/or drying.
I ran into a minor hiccup while trying to set up Dryer Control. Initially, the washer and dryer would not pair via Bluetooth at all, but following a firmware update, they paired right away!
So far, I have been very pleased with the results of this set. We are going to buy pedestals at some point, but they are pricey at $280 a pop.
Congratulations on new set. Use in best of health.
We told you so! *LOL*
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?85339
Welcome to our world! We've got you now....
While one's Maytag wringer washer is fine one supposes for odd big or bulky item that our European washers cannot cope with, wouldn't want a top loading washer with central beater for main or only washing machine.
Congratulations on your new GE front load washer
I think you'll like the performance of this much better, the new dryer is probably gonna be a lot faster. Once you got the bird and bird nest out of the vent. That's for sure.
Putting the washer on the pedestal will probably make the vibration a lot worse, if the dryer shakes when the washer is spinning, the floor is not strong enough for a pedestal on the washer.
With the serial numbers blacked out on these were these scrapped machines or did you do that for photo purposes? If you obliterate the serial number on the machines, you will void your warranty.
John
John
The bird was indeed removed from the vent. It was stuck in the old dryer hose, which Home Depot took with them upon hauling away the Frigidaire. I saw one of its feathers on the floor beneath the dryer.
No, these machines were not scrapped, they were BRAND NEW. I blacked out the serial numbers on my phone's Photos app purely for photo purposes, as I feel a bit paranoid about exposing details of my very machines online. In reality, the numbers are unmarked.
Great! Even though this wouldn't be my first choice for a FL washer/dryer .. I would totally own this set before any top load washer...To me, even the worst FL washer on the market is better than modern TL washers (I'm not talking about SQ) I'm talking about all the other ones...
And these are actually not bad looking at all! One thing I will mention since it's new. I ran across a video the other day of a guy who has this exact machine... he was not happy because he felt like there was always a smell in his clothes. Well, he found out why... It was the freaking dispenser. The way it's designed it has two pieces snapped together.. blue/white... It looks like the way they are snapped together make it more difficult for the dispenser to dry out... and there was MOLD everywhere when he was able to get the blue piece off..The washer itself was fine... it was the disepnser that was the issue..
I'm not sure how to deal with removing remaining water from a dispenser that has a built in tank to hold detergent. I mean, dispensers that don't have the built in tank (like mine) I just take it out when done and go to sink and dump any remaining water it holds then just set it on top of the washer so that not only the dispenser tray can dry, but the dispenser housing can get air as well.. But with these, how do you dump out any remaining water.. can you even do that since it's full of detergent? I don't know...
Cleaning the dispenser area on the front load washer
I have hardly ever taken the drawers out of my Speed Queen's, if you use the bleach dispenser periodically, there's enough vapor from the bleach inside the dispenser housing that you will never have mold. I looked at both my machines a while ago, and there was no mold in them I do leave the drawers a jar. I don't bother trying to get the last drops of water out. It doesn't hurt anything and is fully evaporated by the next time I use the machine in a few weeks.
John
<blockquote>...by the next time I use the machine in a few weeks.</blockquote> John, many households run their washer much more frequently such that they never dry.  Consider families with children.  My mother can't stand to have unwashed items accumulating.  She has a couple outfits or a dish rag and couple dish towels ... must wash them.  I've tried to explain that she's putting more wear on the machines and using more water than larger load less-often, to no avail.
Yea - some use their washer every single day... Me? I don't .. I get it all done, let it build up, then do a bunch...so I can go a full week between doing laundry. I can imagine families doing laundry daily might run into issues with dispensers not ever drying out... so they would neeed to clean them...and the housing every now and then.. Only with the GE dispenser, and maybe others, you can't take the pieces easily apart to clean all the crevices..
The designers seem to be focusing on mold growing in the actual drum/boot and not even considering the dispenser/housing
Across Europe average household does laundry between 3-4 times per week.
https://www.the-independent.com/life-style/uk-adult-average-washing-quantity-b1967004.html
https://admin.betterlivingprogram.c...23/04/ELECTROLUX-TRUTH-ABOUT-LAUNDRY-2023.pdf
Mind you with previous standard 5kg (11 pound) capacity front loader daily or every other washing was almost required. More so in homes with children and or if people used proper laundry day technique such as washing like with like.
Lack of tumble dryer also plays or played a role. Unless one has large enough area to hang multiple loads of washing to dry, smaller loads are easier to manage on that score.
New larger capacity front loaders are all very well, but issue still remains of washing like with like. If one doesn't have enough washing of a particular load it's either run machine at lower capacity (not good for host of reasons), or let things pile up until one does have enough for a full load. Last bit is an anathema to some, so there you are.
https://www.google.com/url?sa=t&rct...download&id=324#:~:text=European%20households
"The designers seem to be focusing on mold growing in the actual drum/boot and not even considering the dispenser/housing"
Well they would, wouldn't they?
With major European and other appliance manufacturers fully sized and on board with cold water washing mould in tub and or boot is first obvious issue. This coupled with rise if not stated preference for liquid laundry detergents and you can see where things lead.
I think the microban helps... and it probably does have it... but I think it's a losing battle with the dispenser design and constant moisture unable to dry out... sure, they have fan fresh from the drum itself... but that does absolutely nothing for the dispenser. To be safe, I'd take it out and leave it out when not being used just so the dispenser and housing can get air... I mean, look at that video.. and this guy in the video has done several videos on his machine and he doesn't strike me as a laundry sinner at all... just the vibe I got.
Personally if that were my machine, I would only use powder and dump it inside the drum instead of inside the dispenser. I'm making a switch back over to using powder once my last thing of liquid is gone. But I'll still put bleach and vinegar inside the dispenser cause like what John mentioned, it shouldn't have a mold issue. I know my LG doesn't have a mold issue and I never take the dispenser out to dry.
I wonder what caused mine to develop pink mold instead of black? It's mold free now but only because I cleaned it and dump dispenser water and wipe off the roof of the dispenser housing becasue when I'm done doing laundry, there's tons of water droplets on the roof of the housing just hanging there from where water was coming into the dispenser... it's no big deal at all I don't mind doing this... I've gotten so used to it
Removing the drawer
I decided to remove the dispenser drawer and set it on top of the washer to let the area dry. Only problem is, my laundry room doesn't have a sink, so I had to haul the entire drawer over to my bathtub to dump out the residual water. While doing so, I noticed that a tiny amount of detergent leaks out of the SmartDispense container, so I'll have to be mindful of that.
On another note, I bought one of those magnetic silicone door props on Amazon the other day. This lets me prop the door open slightly to further dry out the drum after using the UltraFresh Vent System. I know the washer has Microban protection, like I mentioned in my OP, but keeping the door ajar is another step to make sure that this machine stays pristine for years to come.
mark_wpduet, I bet that the pink mold was caused by an overuse of fabric softener. I know because my old LG had this stuff accumulate in its drawer. And yes, I removed the drawer to dry it after the day's laundry was done. That fabric softener residue in the LG was slimy and gross.
Hmmm. I've never been heavy on FS and when I use it which most of the time I don't use it at all, it's very sparingly. I wonder if/when the FS is dispensed perhaps traces of it gets splashed up or something...
I don't know. I have pretty diligently taken my dispenser to the kitchen sink and taken it apart and kept it clean from build up (I don't have a laundry sink either)
:( ...everything comes apart.. It's really not an issue for me now.. I just thought it was so weird how OCD I was about it and yet even still it was happening..
the only thing I'm doing differently now that I was not doing before is leaving the dispenser completely out sitting on top of the machine at least for a day or two before putting it back then just leaving it open..
In the future it might be easier to just grab the dish rag and dump the residual water on that... and any detergent that leaks can just go onto the dish rag... usually it's not much residual water (at least in mine) then just let it sit on top when not in use.. this way you don't have to haul the dispenser to another room
A couple days ago
I washed a huge load of my darks and colors; it consisted of T-shirts, sweatpants and underwear, along with my chef coat and aprons from work (I am a dishwasher at a private restaurant set within a country club). This load filled the drum about 3/4 of the way. I used a couple of CLEARALIF laundry detergent sheets, along with a small amount of OxiClean.
Once the washer was done, I was overall thrilled with the results. The food stains were completely gone from my work clothes. Oh yeah, and there was no more white, linty residue on the darks! The dryer took just under an hour to dry the load.
My old Frigidaire top-loader suffered from rather poor performance; with a full-to-the-top load of mixed items, the clothes just floated on top, and the agitator pulled them back and forth with no turnover whatsoever. Everything was just scrunched together and not fully submerged, which most likely contributed to that white gunk on darks. In addition, thin articles of clothing, such as workout clothes and pillowcases, would get "eaten" and stuck under the agitator; I would have to pull them up and out from under there after a cycle was complete. Lastly, the Frigidaire's auto-sensing water level system wouldn't fill with enough water when washing bulky items such as dog beds.
However, thanks to the GE front-loader's superior wash action, I feel very confident that my clothes are getting cleaner than they ever would in a top-loader. And, it's nice to know that my clothes won't get cooked in the dryer, thanks to the SensorDry system. Overall, this is a phenomenal laundry set.
