GE ...New Wash Plate .
Cool
I kinda like the newer harmony machines. I know that originally they came from LG, but I believe these are being built by GE directly. Funny there hasn't been any complaints about the harmony machines exploding during spin.
Malcolm
Maybe the holes along the ribs of the impeller/wash plate create a bit of a surge of water that helps push items in the load upward to aid reverse rollover.
I've come to enjoy watching the center of the load "bloom" during agitation in the Immersion Care. And like a flower, it blooms very slowly, LOL.
Great photo of you and the new GE's, Darren!
not even body temp?!
I couldn't help noticing that the hottest wash (96.2 F) is not even as hot as the normal temperature for the human body. What are the "engineers" that design these stupid things thinking?
What if you have a kid come home with lice? How would you wash their clothing in water hot enough to kill them? There should be some sort of override.
The ability for at least some front loaders to achieve "sanitary" temps of 152F+ degrees is one benefit of front loaders over these new TL washers.
Yeah, they don't say which temp they used, though I assume the one that's preset with each cycle. I sure hope it's Warm in the case of this GE because a hot Whites cycle at only 92F...?
Wow, it tops out at 96 degrees? I guess the Immersion Care is not alone in the "cool is the new hot" division.
I've said it a hundred times: Don't buy a washer without an internal water heater!*
*I broke this rule with the recent purchase of a Frigidaire Immersion Care top-loader. In my defense, I had no idea the hot water was dumbed-down to 'cool'. And I have a front-loader with a heater, so I'm covered.
If the Delicates cycle was 81.4F, and it used less than a quart of hot water, that tells me that the cold water intake must have been very warm. I wonder what the wash temperatures would be if the cold intake was 36F, which is how cold my water can get in winter.
as with any ATC set temp....it would add more HOT or Cold to achieve the set temp....
sometimes its a benefit, when requesting HOT/WARM water...it will purge the line until the HOT water gets there......I always purge my lines at the sink before starting the machines...
then again none of my machines dub down that far....except the Cabrio, but a HOT wash will only drop down 10 degrees from the water heater setting...so far, I can't complain....
on the Cabrio, while you can't turn off the ATC, certain cycles(heavy duty, whitest whites), as well as turning off "energy save" and "eco boost" will give warm to hotter washes...than something like Casual or Delicate/Handwash...but you also would see changes in wash times and wash pattern....
try to override where you can, but sometimes it doesn't always work...
