GE NON-FilterFlo Set
filterflo
Jan 9, 2019
0
Chicago Area
The other set that I brought back with me from DC was this 1955 GE Washer and Dryer Set. This is a 1955 set, just before the FilterFlo wash system was introduced........This is still the double belt set with a double clutch pully system.........I have the trim piece from the front of the washer, but it was loose so I removed it so it would not get bent........
Door port opening.......This dryer is working and actually needs nothing but a good cleaning up and a little cosmetics. Tom Anderson helped me move it and hook it up and we were both amazed by how quiet it was. It was almost silent!
pic of the washer motor and clutch. The clutch shaft has actually broken in two...again, this was GE's two belt system and double action clutch..........the next years models went to a single belt tranny and single clutch. A much simpler and more dependable design.........
I had an extra motor and double clutch on a scrap washer that I had saved. Its hard work hunting down, saving these parts and then hunting them up when needed, but boy do they come in handy when you need them!. I almost tossed this out several times, after tripping over it moving it from here to there.........now I need it and GLAD I saved it! Yay!
Backs of the GE set...........And yes, like a lunatic, I bought home ANOTHER set yesterday! I just cant quit! Well, got to save them when we find them.........will post pics of them soon.........another great find! Jimmy
They ARE VERY NICE
Is the dryer a perforated drum with a lint screen at the toe kick area? or is the screen somewhere else? thanks nice pics. alr2903
Ok, I give up. how does the 2 speed clutch on the older ones work? I sorts remember the later 2 speed clutch - the one on my mom's old GE flaked out in the late 80's, but I remember how it would start out slow for a few seconds, then click into regular speed. I think the bearing for plate the high speed arms ride on siezed up, so it was forever stuck in high sigh speed after that...
The other thing it did in it's later years was make a horrid grinding noise when startingh in either activate or spin (but it ran smoothly)...
Ok, anyway, I'm guessing the early model GE transmissions were different than the later ones? Did they change this with the two speed clutch change, and oh yeah, how did the Versatronic one work?
Anyone got pictures showing these things? I love seeing internals on stuff.
(and where's the GE wash videos? I'm curious as to how the earlier solid tub ones worked, esp the filter flows and AW6..)
Its not a two speed clutch, its a double belt clutch. One belt was for agitate, and the other was for spin. Its one speed and one speed only..........
Jimmy, outstanding. I wish someone around here knew the GE history right about that time. Friends of my parents had a similiar style set. The difference was, there were parallel knobs on each machine. On the washer, inbetween/middle of the two kinobs, was the turqoise water saver button that ya pushed down to activate. The 2nd know was water temp as well as "off". I remember our owners manual had a looseleaf marketing piece in it and I believe the temp dial was referred to as the fabri-flex dial. And here's the confusing part. The washer we got, to replace the 48 bendix to keep me out of it, did not have a FF in it. It looked just like the inside of this machine. However, the panel looked exactly like the FF Jon Charles has--center lighted dial with the copper accents and turqoise buttons on the right for water saver, hot, warm, and off. I did not have a FF, I would have remembered!! I wish someone around here could place exactlyu what we had. It also had on the front left of the cabine, in a turoise banner on the right, emossed with chrome automatic washer words.
Bob, the GE with the two knobs on each side is just a slighter later model than this one. That model was in response to this model, as this model surprisingly has no OFF position on the dial. Once you start it, it either has to run thru the complete cycle or you turn it by hand thru all the cycles to OFF. There is no PUSH/PULL Off on this timer. Not the best design........I believe they incorporated the OFF swich on the Water Temp control dial on the two dial models..........
Great find Jimmy! And that washer is sure a rare find. My mother had that same model dryer, but with a Kenmore washer with the "target" type timer console.
Congrats! It's beautiful set...
Your washer's configuration seems to suggest that it's actually a K or L series machine, model 450 or 550 (K=1953 or L=1954--they appear to be virtually identical), based on GE service literature. The "M" series '55's appear to have the single belt and a slightly different bezel than your machine.
Additionally, the two-dial "650" machines were also produced during all of K,L & M series years.
Moreover, the interesting two belt drive system allows it to have a higher spin speed than the later single belt machines.
I have attached the exploded pics of "representative" machines:
