Folks,
Ever since we've owned it, my 1966 GE J486 P*7 40-inch range has never done a great job of self-cleaning. I finally decided to measure the temperature during cleaning, using a digital thermometer and high-temperature thermocouple (rated to 1832F!).
During a cleaning cycle, the "lock light" came on at 550F, which makes sense, as that's the highest selectable cooking temperature. But then, the oven temperature peaked at 575F-580F and stayed there! As I understand it, the self-clean temperature should be closer to 880F! I see the "oven temp" light change slightly in brightness, presumably as the heating element cycles on and off.
The oven temperature sensor was replaced in 2012 with part WB21X158, to fix a non-operational oven, but my problems with self-cleaning pre-dated that fix.
What do you think is the problem -- the thermostat? Would anyone have the part number handy? Thanks in advance!
Dean
Dean
