GE profile maxus washers
gelaundry4ever
Nov 18, 2014
4,108
Temple, Texas, USA
Hello everybody. I've always wondered about the GE washers from '95 and later - notably the post filter-flo GE machines. How much engineering went into the laundry pair? I have read the article about it having a steel drive transmission. What do you think? How many of you had experience with this laundry pair? I'd like to know. Thank you.
http://www.thefreelibrary.com › ... › June 19, 1995
washer article
I will try this again.
Interesting write-up.
Maybe the transmissions ARE (were, since these are phased out now) built with steel components. I cannot find any pictures of the saw-blade gear interiors.
The majority of washers in apartments I've rented have been the lower end GE washers and dryers post FF era.
Here's what I know:
- They do clean decently well.
- They are more violent than the Shredpool DD design, since they have a very fast 90deg. arc. 2 speed machines are preferred.
- The plastic, ribbed Xtraction baskets actually wring out a lot of water for a slow, plastic tub.
- Their very small transmissions have reciprocating gears on a bar.
- They have fairly well built, quiet 1/2HP induction motors. I've seen them made in USA, China to India.
- The mode changing clutch is directly attached to the motor spindle. (non hydrowave)
- Hydrowave models use the exact same mechanical innards as post FF GE washers, sans the digital motor/transmission-less drive system.
- Hydrowave machines have a variable arc from 360 to 180 degrees.
- Hydrowaves also have some kind of load sensing technique, where they spin the dry tub of laundry and measure the kinetic energy.
In summary, they're fairly cheap on the surface, but they do tend to last several years or more if you get a good one.
Their matching dryers seem to be the same dryer design as from the the FF generation, with that giant grill vent in the back. And it's actually my favorite dryer design ever. Even a little more than the Maytag design.
One caveat is after advanced age, the GE dryer drums can sag in the front, and clothes can catch in the opened drum seam. Watch out.
lint filter and other features
I believe these GE washers have a hidden lint filter underneath the agitator. I have noticed the auto-balanced suspension system works very well. The suspension is different from their aircraft cable suspension system. There is also a fluid filled balance ring. I hear that they also fill with a thin sheet of water. Perhaps somebody who is a GE expert may know. I also wonder how hefty their motors were. These washers and matching dryers seem to be built tough in the long run.
Profile maxus still running
My parents bought the GE profile maxus pair when thy first were introduced. I am happy to say they are still going strong 20 yrs later-today with no repairs. The only comment my mom makes is she misses the mini basket from her 1975 Ge filter flo.
