If we call those who don't want to inhale coal fumes 'tree huggers', what do we call those who DO? Mercury huggers? Soot sniffers? Sulfur dioxide gluttons?
I'd let them build a nuke 'in my backyard' but I don't want a coal plant even in the same county where my air comes from.
All boiler plants take hours if not days to come online, unless they're kept hot even when they're not running. Natgas turbines on the other hand, can sit completely idle and come online in minutes. The current wisdom is building these turbine "peak" plants. They're cleaner than living by a freeway and need no cooling reservoir so can be put anywhere, run and stopped cold as needed.
I propose turbine/electric for transportation. Not like Chrysler tried, with the turbine turning the wheels. Turbines like to run one speed which ideally drives a generator then THAT drives the wheels like in a Prius or Volt. Turbines have 2 moving parts. They're the most power/weight efficient engine. They can be made to run on almost anything. Kerosene (but that stinks), frenchfry oil (stinks too), natgas, LNG, propane, hydrogen. They'll even run on vodka. But not coal.
