turquoisedude
Discovery and Dilemma....
I must admit that I did not expect the motor to start up so readily. The tub seems to be turning quite easily in 'tumble' mode. I manually advanced the timer through the cycle and I could hear the fill solenoids engage. The pump solenoid engaged and the pump ran smoothly. I heard the spin solenoid buzz but the tub did not accelerate to the blindingly fast 200 RPMs.... And as I had not hooked the 240v supply up, I had no way of knowing for sure if the dry function would work...
So here's the dilemma: Should I try and do any further work on this machine? I bought it as a 'parts donor' not expecting anything to work on it. My gut instinct is to grab the thermostat and swap it with the one in the Kitchen Centre (and investigate and hopefully resolve the timer power issue on that machine).
However, I think I should try a 240v test on 'Project Syracuse' to make sure the darned thermostat even works...
I have a lot of projects on the go, so needless to say, I'll be under pressure to 'get that bloody lot out of the garage' by fall. I guess I should just move down to Ogden full-time... LOL
Thoughts? Suggestions??
