GE2800 Photos
John, it is you who continually makes global generalizations versus facts.
Show us all where the GE motors (or any motor for that matter) is only 30 percent efficient. This is just a random figure you pulled out of the air, that you thought would prove your point.
Show us the data indicating rpms of the older GE DW motor versus the newer PSC motors. (maybe the are the same, maybe not--it would be interesting to see)
Show us your data that proves GE had the "most inefficient motor ever put in a dishwasher." Maybe it's true, maybe it isn't. Let's prove it, to everyone, and quite making up things.
Even if it is true that in the entire history of the dishwasher, this is the most inefifficient motor ever made. GE still managed to outperform Maytag, KitchenAid and Whirlpool in washing performance as per mid 1980's performance data from Consumer Reports. If I recall correctly, GE's did this with less current draw, for the motor than the Maytag RR. I am not sure what the KitchenAid and Whirlpools motors drew, but probably very close to, if not exceeding GE's 5.5 amps.'
Also, if GE wasn't capable of washing dishes/g;assware in the corner of their upper racks, this would have downrated their performance scores by Consumer Reports and would most certainly been mentioned by CU.
No, my friend, a GE DW motor is not putting out almost 500 watts of heat energy. Can you imagine a 500 watt heating element in that small enclosed space beneath a dishwasher glowing for close to an hour?
Go back to back issues of Consumer Reports and look at the repair ratings for General Electric dishwashers for the 1970 through the 1980's--impressively good.
I have nothing against the newer 1.8 amp China-made PSC motors. I think they are better than Frigidaire's and some of the other brands. I got one in my kitchen right now, but i don't like it as well as the motor in my GSD 2800 in my kitchentette. And I get better washability in the 2800.
Yes, water does deflectm and change direction when it hits a stationary object. To say water doesn't deflect, is one of the most ignorant statements I have ever heard you make. When an object or fluid with a given trajectory encounters another object with mass, especially with equal or greater mass, a change in the trajectory will occur. You should have learned this in Physics 101.
If this didn't occur, water would not enter up into glassware when its at an angle. A colloquial term for the change of trajectory, is called splashing.
Remember the video, John, of the impeller dishwasher that one of our members posted on this site. When there were no plates in the lower rack, water coverage on the top rack was close to nill.
When the member put plates in the lower rack, the water was directed (deflected) to the upper rack with impressive force.
GE DWs
Really not worth responding to Barry, almost every statistic you made in you last post just changed, I won't even try to keep up with your changing opinions.
I will let Mark do some testing later this month, eventually when I get my WALL OF DISHWASHERS installed we will do some real comparisons. But I should really know better than debate someone that also thinks that the GE series wound disposers were a great product LOL.
I still miss our old potscrubber.
Wasn't as fancy as those though, ours had the timer dial you actually turn and the options were
Potscrubber|Normal Wash Heated Dry|Evergy Saver.
Though, it did have a "light wash" option that you could turn the timer to.
Tell me, tell all of us, what statistics changed, John. Tell us exactly.
I am not the one who fabricates figures to support an argument.
We're all still waiting to see your data source for the speed and efficiency ratings for the older GE dw motors versus sthe newer PSC.
I was going to ignore your comment on the dispoer, as you are getting off topic for the thread.
Go back and re-read the thread a few months back on disposers. You were the one who thought that food waste disposers had spinning blades. I was the one who had to explain to you how they actually functioned. Not only did you not know how a disposer worked, but you condoned putting caustics, like lye, in one.
Those two things alone, I think totally negate any opinions you might have on disposers. LOL
I too, am bowing out on this thread. This site is for sharing information (and opinions) on appliances. I enjoy bantering with you, John. But it seems to be getting personal, and I don't want it to.
Yes, we should get together and run some performance tests. However, we will probably have to put boxing gloves on now and then. HeHe Maybe we could ask Robert to referee. But, I bet we would have a lot of fun.[this post was last edited: 5/10/2012-22:06]
Old GE mechanism vs new GE mechanism
Adding my 2 cents here I think what might be behind Mr. Bwood's observations are the fact the new style pumps have slimmer, redesigned bodies. This does not appear to make much of a difference in low water models that have a restricted wash arm orifice, but in older models with a metal wash arm and partial telescoping tower with a full opening (to the pump outlet) I do notice less water pressure.
I did do a test once where I placed a newer style motor on an older wide body pump and from my observations the water pressure was equal to what had been in there prior (old motor and old pump body).
Also, I want to point out that the listed amp draw by itself for both motor means little. First the listed current draws are practically estimates, anticipated values under maximum specified conditions. That is current draw under a listed rpm driving a listed torque under listed voltage. (Think laboratory conditions). Come real world the motor will be driving more or less (usually much less) than what was asked for when building said motor, and thus its current draw will certainly vary in use from its listing. By how much is often best answered by a clamp on amp meter. The values listed on any appliance are more along the lines of worst case scenarios telling an electrician how to size the circuit for code purposes. Which motor received the worst case fudge factor is hard to say without testing.
Second current draw on a motor is not just watts, but a combination of power factor (VA) and watts (W). Its possible to have a low power factor motor drawing lots of current in the form of VA with less current dedicated to watts (torque x speed and heat), and its possible to have a motor drawing little power factor (reactive power) while being mostly all watts (heat and torque x speed). As mentioned, watts are subdivided into two categories: output power and waste heat. It certainly is possible that the shaded pole motor is putting out 100 watts of rpm x torque, 250 watts of heat (3 amps) and the remaining 2.5 amps being nothing but reactive power which gives off no heat or torque.
VERY LOW STARTING TORQUE
I agree 100%, any engineering book on motors will tell you an SPM has next to no starting torque, but that does not reflect on running torque. Not saying one motor puts out more shaft power than the other, just that much more plays a role then being discussed here.
dishwasher motor power consumption
My observations about dishwasher motor power consumption come from placing an amp meter on the leads to the motor. The newer style GE motors to drawl only about 1 1/2 A roughly 150 W. The older style shaded pole motors do you draw nearly 6 A or around 600 W of power.
Your claim that 250 W of power just evaporates as reactive power don't make any sense you should explain it to the power supply people Lol. I can assure you that all 600 W is either going into pumping water or heat it's that simple really.
Thanks for reviving this fun old interesting thread.
I don't know what the waste heat rate was of the SPM. But as a kid, I was able to touch the running motor with my hand. If it was in excess of 60 or 100 watts, I doubt i'd be able to touch it.
Granted it blew off tons of heat, but c'mon, near 400 watts of waste heat?
That's ridiculous. It would've melted the plastic tub after time at that rate.
They certainly had low starting torque.... If any.
In fact, many GE dw manuals had instructions on how to unstick a stuck SPM pump.
As for that missing wattage loss? It's possible a lot of power went to actually driving that giant sheet metal fan.
Another point too, to reiterate.....is.... As crappy as a motor as GE put I millions of dishwashers.....they were surprisingly market competitive for many decades.
6 amps does not automatically equal 600 watts.
"Your claim that 250 W of power just evaporates as reactive power don't make any sense you should explain it to the power supply people Lol. I can assure you that all 600 W is either going into pumping water or heat it's that simple really."
I never said that. Notice how I clearly made the distinction between the two by using the term "watts" and "VA". 250 Watts, which would be restive looses within the motor (heat radiated into space) having nothing to do with reactive power.
"you should explain it to the power supply people Lol"
Pure assumption...
Power factor and Shaded pole motors
Not to confuse, but this is a good starting point.
"The disadvantages of shaded pole induction motor are
Low power factor.
The starting torque is very poor.
The efficiency is very low as, the copper losses are high due to presence of copper band.
The speed reversal is also difficult and expensive as it requires another set of copper rings."
http://www.electrical4u.com/types-of-single-phase-induction-motor/
Page 10 compares the different types:
http://www.tcf.com/docs/fan-enginee...irrel-cage-motors---fe-1100.pdf?Status=Master
As stated in both, and as I have long known, the power factor of a shaded pole motor is not unity but rather only 50 to 60%, or .5. This automatically means it is physically impossible for that motor to be generating 500 watts of waste heat with only 5.5 amps.
Reactive power:
https://en.wikipedia.org/wiki/AC_power
I will post more to back up my claims latter.
Shaded pole verified
I remember seeing some comments on whether the older Hot motor was shaded pole or not.
Just wanted to show for the audience, straight from GE themselves, the old motor was indeed shaded pole.
And they refuse to horsepower rate their motors.
Horse Power
Thanks, so they are indeed SPM :)
Thinking about the numbers and talking with others Id say 1/6 max, probably less. But that is not something GE wanted out on the market considering every competitor was bragging about a 1/3 HP motor.
Fascinating thread Chet, but there doesn't seem to be a conclusion.
Did I miss it?
Am I to understand the SPM would put out around 200w of waste heat?
That's still ridiculous lol.
Silly GE.
I suppose nobody cared back then.
And the market for quiet dishwashers is likely what really pushed them to PSC.
Thanks, and lol, like many threads on that forum it does get lengthy. But basically we are trying to find the exact values, or at least those close to them with the information given. An actual power factor reading done by a kilowatt meter can help narrow it down, and knowing the amount of power the impeller and fan consumes will give exact numbers. However in so far the estimated waste heat is around 200 watts.
I am sure the number will get more refined and I will post them as they do. Not going to give up this easily, Ive always wondered about it but never had the guts to ask.
Pump performance curve
Since GE didn't provide us with a HP rating on any of the motors, it will be hard to tell how efficient these motors truly are. Although we can hook up an ammeter to see current draw during washing, we will never know the real efficiency. Centrifugal pumps draw more amps as you get to the top end and bottom end of the performance curve. And depending on how steep the curve is, there may be a narrow window where flow vs amp draw is most efficient. Im curious to know how efficient the SP motor is especially since it waivers in output speed as water is introduced and normal washing happens.
Next time I hook up the GE, I will see how much it pulls on startup too. SP are inefficient motors, and their speed is always less than that of a capacitor start motor. I feel the replacement capacitor start motor should work better as its speed will be much more consistent around 3600rpm, and they handle load changes much better.
There's no question
that motor efficiency has improved over time. It is, however, worth noting that shaded pole motors do have a few advantages over some other designs which can, under certain circumstances, justify their use despite lower efficiency. 1) Stalling out doesn't burn them out.  2) Super simple: If it ain't there, it can't fail. 3) As long as they are lubed, they have an indefinite life expectancy. As to our Twenty-Eight Hundred, the original motor has now run daily since 1984 with neither shaft leak nor broken chopper (a genuine weakness). That's not bad when you consider she's on her third mainboard and calrod.
Amount Of Waste Heat From A GE SP DW Motor
Is going to be around 375-500 watts, when you find out the exact # let us know, I have worked on enough of these to know what I am talking about.
The great thing about these crappy energy hog motors was they were great at drying up all the water that leaked at the trip shaft seal and even the main pump seal, I have seen many GE DWs that had leaked for years and the leaks went unnoticed because all the hot air blowing around dried up the water, if only they had directed the hot air through the DW chamber they could have left out the heating element for the dry cycle.
Formula
For calculating Watts on an AC motor:
<em style="box-sizing: border-box; color: rgb(34, 34, 34); font-family: "Times New Roman"; font-size: 22.4px; font-weight: normal; line-height: 40.32px; background-color: rgb(255, 255, 248);">P</em><sub style="box-sizing: border-box; color: rgb(34, 34, 34); font-family: "Times New Roman"; font-weight: normal; background-color: rgb(255, 255, 248);">(W)</sub>[COLOR=rgb(34, 34, 34); font-family: "Times New Roman"; font-size: 22.4px; font-weight: normal; line-height: 40.32px; background-color: rgb(255, 255, 248)] = [/COLOR]<em style="box-sizing: border-box; color: rgb(34, 34, 34); font-family: "Times New Roman"; font-size: 22.4px; font-weight: normal; line-height: 40.32px; background-color: rgb(255, 255, 248);">PF </em>[COLOR=rgb(34, 34, 34); font-family: "Times New Roman"; font-size: 22.4px; font-weight: normal; line-height: 40.32px; background-color: rgb(255, 255, 248)]×[/COLOR]<em style="box-sizing: border-box; color: rgb(34, 34, 34); font-family: "Times New Roman"; font-size: 22.4px; font-weight: normal; line-height: 40.32px; background-color: rgb(255, 255, 248);"> I</em><sub style="box-sizing: border-box; color: rgb(34, 34, 34); font-family: "Times New Roman"; font-weight: normal; background-color: rgb(255, 255, 248);">(A)</sub><em style="box-sizing: border-box; color: rgb(34, 34, 34); font-family: "Times New Roman"; font-size: 22.4px; font-weight: normal; line-height: 40.32px; background-color: rgb(255, 255, 248);"> </em>[COLOR=rgb(34, 34, 34); font-family: "Times New Roman"; font-size: 22.4px; font-weight: normal; line-height: 40.32px; background-color: rgb(255, 255, 248)]×[/COLOR]<em style="box-sizing: border-box; color: rgb(34, 34, 34); font-family: "Times New Roman"; font-size: 22.4px; font-weight: normal; line-height: 40.32px; background-color: rgb(255, 255, 248);"> V</em><sub style="box-sizing: border-box; color: rgb(34, 34, 34); font-family: "Times New Roman"; font-weight: normal; background-color: rgb(255, 255, 248);">(V)</sub>
<sub style="box-sizing: border-box; color: rgb(34, 34, 34); font-family: "Times New Roman"; font-weight: normal; background-color: rgb(255, 255, 248);">[COLOR=rgb(0, 0, 0); font-family: serif; font-size: 16px; font-weight: bold; background-color: rgb(255, 255, 255)]Somebody will have a better figure, but if I recollect properly, this motor has a power factor of about .85. So - If the motor draws 6A @120VAC, then we're looking at 612 watts.[/COLOR]</sub>
<sub style="box-sizing: border-box; color: rgb(34, 34, 34); font-family: "Times New Roman"; font-weight: normal; background-color: rgb(255, 255, 248);">[COLOR=rgb(0, 0, 0); font-family: serif; font-size: 16px; font-weight: bold; background-color: rgb(255, 255, 255)]Now, I don't wish to be pedantic, but 100% of the work done by that motor is, ultimately, going to be heat.[/COLOR]</sub>
John's in the ball park on this. hell, anybody who's seen the fans on these knows that.
And, I LIKE shaded pole motors.
Actually, the Twenty-Eight Hundreds have a better power factor correction that people might expect - look at the power supply for the brain on them. I'd not be surprised it things add up pretty close to 1 in the end.
Chet,
That would be a real world way. Anyway we cut it, these motors are horribly inefficient. And loud (blower). Still, over thirty years of constant service (I do re-oil the felt pad as per GE instructions every year or so) suggests they did get something right.
Would I replace it with the capacitor split-phase induction design if it were to fail?
Yes. Until then, it works well and makes a happy sound.
Efficency
No, trust me, I agree with all you guys. A shaded pole motor (even in the 70s and 80s) was RARELY used in anything larger than a box fan due to the weight and inefficiency. I could be wrong in that some furnaces might have been SP, but thats it that I know of. No one in there right mind would make a 1/6 shaded pole motor, but I guess GE did. Part of me is saying it might have been marketing (think vacuum cleaners) where 5.5 amps looked better than 2 amps, but ultimately those decisions remain as secrets buried deep in GE's past.
Question. For you guys who know GE DW, any idea how much power the impeller itself uses to pump water? Im guess is at 100-150 watts, but be wrong in that regard.
As for myself I like the PSC a LOT more than the shaded poles. Quieter and no wind blowing about lol. Plus the new pump bodies make rinsing a heck of a lot better.
Suitability
One of the great things about the tremendous advances in metallurgy, manufacturing and electronics is the range of choice we have, today.
Back in the 1970's, an electronically controlled motor - Philips had them in their washers, for instance - was a rarity.
Today, we expect 'digital' motors to run at 100,000rpm + without the slightest hick-up.  There are reasons we still use them, though:
As long as they're lubricated, they have the longest life expectancy of any electric motor).
Run in very very cold and very very hot environments, as well in environments in which enormous temperature variations over a short period of time are normal.
Always start in the same direction (I'm not including the switched wire loop versions in this).
Self-starting.
Can be built as synchronous motors (I'm not getting into that discussion again).
Many can be speed controlled by super-simple electronic circuits.
Don't burn-up when stalled.
As close to silent, when properly built, as a motor can get.
Easy to magnetically shield.
Super easy to use the stator windings as a transformer.
Cheap, cheaper, cheapest to build.
Disadvantages - power PF without correction. Poor (that's an understatement) starting torque, lower efficiency than many other designs.
Shaded pole motors were and are an answer for applications in which certain needs take priority.
Inexpensive to build.
Reliable - if it ain't there, it can't break down. Capacitors do have a limited lifespan and aren't tolerant of the high heat these motors can put away without difficulty.
Eventually, no doubt, we'll see more efficient motors, but for the moment they still fulfill a market niche.
Whether GE really needed to use them for dishwashers is a question I think we'll all have forever.
Agree with all the above. Everything has its plus and minus and thus its own niche.
I can't speak for GE's choices, but one thing is for certain: GE not only managed to put millions of descent dishwashers in homes all over the world, but inspired countless children to become future engineers and appliance collectors.
One of the earliest memories was playing around with a pot-scrubber and latter taking apart a GSD500D. Good times lol ;) But no doubt it was GE that started my interests in appliances and consumer electronics. It was always fun to toy around with their products.
GE DW SP Motors
GE used these motors for one reason and one reason only, They Were The CHEAPEST  Motor To Build That Could Do The Job.
Every other DW manufacturer used a better MORE durable motor in their DWs including companies like D&M.
You are correct that these motors are simple, but simple does not mean they are necessarily more durable, because they run so hot and had cheap sleeve bearings and were poorly balanced I have no dough that most newer designs will outlast these SPMs. You are correct that adding a capacitor adds one more thing that can fail, but when you consider that modern capacitors on appliance motors have a life span of at least 50 years it really does not matter, LOL. I think I have seen one bad capacitor on a new style GE DW motor in the last twenty years.
Yes I agree Chet, that GE did introduce a lot of American homes to the work saving convenience of a built-in DW buy building them so cheaply and getting new home builders to put them in homes. A local development near here where Kettler Brothers built 1800 homes from 1963-1969 all had GE kitchens and they all had a GE BIDW. One of the men that worked for the builder said that GE sold them the DWs for $59 each.
The other great thing about GE selling all these cheap DWs to builders was the replacement market after they rusted out and the motors and pumps failed after 5-15 years, by that time most consumers were hooked and went out and bought a good DW, the reps at WP, KA and Maytag loved GE for this, and GE even put Waste-King on the DW map because of the way GEs rusted out people were looking for something that would not rust, LOL.
