New replacement bulbs
I have found a new replacement for the old germicidal lamps used in appliances. They have the same spec's as the original but the shape is different. The new bulbs have a tubeular shape, not the globe shape, and are a little longer, check to see if they will fit the space provided in the appliance. They must be used with a ballast of some type as this is an arc lamp. Most appliances used a 40 watt light bulb in series with the germicidal lamp, others used a ballast like a flourescent lamp uses.
www.1000bulbs.com
UVC and UV Light Bulbs for Disinfection and Purification | 1000Bulbs.com
Buy UVC light bulbs and germicidal lamps here! We carry a wide range of uv tube lights and germicidal bulbs for commercial applications at 1000Bulbs.com!
