Reply #16
Here’s one thing I’ll note though, since I mostly use the lower temperature setting on my customized Maytag dryer, the front of the drum isn’t nearly as hot towards the end of the cycle and probably is somewhere in the 120F-130F-140F range before it reaches the cool down. The Maytag DG306 I have is even more gentle, the front of the drum is a little on the hot side but as the cycle progresses, the cooler and cooler it becomes (same with the front of the cabinet since the shroud is at the very front of the inside of the cabinet), even monitored it when I installed the low heat 120F cycling thermostat just be sure everything was working correctly. The front of the drum when empty for testing purposes was somewhat hot to the touch, but not burning hot tot he touch. Easily one of the gentlest dryers I’ve ever used, shirts I bought in 2020 with vinyl decals didn’t show any signs of cracking after being dried in that dryer for 6 months.
