Goodman AC off, Goodman furnace ON
washman
Sep 8, 2013
1,972
o
Yesterday, for the first time this fall, I fired up the union made Goodman furnace. Yes, it got pretty darn chilly here, especially in the mornings. My blood is still too thin from the summer so I gave it to my suburban induced softness and switched her on. Ran like a champ, plenty of warm air brought the house temp up in short order.
Also dragged out the LL Bean flannel and the Electrowarmth mattress warmer. I cannot sleep in a cold bed in the fall/winter so I run the Electrowarmth on LO or 2 and it keeps my back and hips from becoming overly stiff. Not even pushing 50 yet and already I feel the ache of age setting in, exacerbated by the cold weather.
On another note, I bought, returned and purchased a better bench grinder so I can sharpen the Husky mower blades.
It started out with a 39.99 POS from Harbor Freight called ahem......."Central Machinery" cough cough. I figured what the hey, it SAID 1/2 HP 3600 RPM, should be good enough to put an edge on Husky mower blades right?
Wrong!
The thing was so pathetically weak that I could stop the motor with just the slightest pressure on the 60 grit wheel. In fact, using a gloved hand, I could grab the wheel whilst running at full chat and stop it with no injury. Seriously.
Well I took it back (it was running very hot also and would shut down on thermal overload) got my money back, did some homework this time. I passed on BIG BOX Ryobi and others as the reviews were basically 50-50. The biggest complaints I read about where lack of motor torque to sharpen anything made of steel. Delta, B&D, Dewalt all were again 50-50. I was not encouraged at all.
Well there is ONE outfit left, in Ft Smith Ark, Baldor that STILL makes bench grinders in the US of A. I shopped on Ebay and finally due to better shipping rates, found a place in Ohio called Mile-x Equipment. For a paltry $12 in shipping, I had delivered a Baldor 612R 6" Grinder, 3600 RPM 1/3 HP unit. Red in color it comes with 36 and 60 grit wheels on 1/2 in arbor holes. It ran so much more smoothly, came up to speed lightning quick, and is far quieter than the Chinese made Harbor Freight unit. I was impressed. I had a 1/8 in piece of scrap steel and in less than 2 minutes of grinding, put one helluva edge and the motor never once balked. And the motor housing remained cool to the touch, unlike the Central Machinery unit.
No it was not cheap and I'll allow the reader(s) of the post to figure out the cost. Suffice it to say, like a Speed Queen, the quality remains long after the price is forgotten. No, I did not set out to grab an expensive grinder but based on my research, I was not about to repeat the Central Machinery fiasco and take a chance on another chinese made grinder.
I was not planning to spend what I did. And what irritates me is how the market is rapidly becoming either stupid cheap or absurdly expensive with little left in the middle. Sure I'll put a wire brush wheel on the Baldor (in case I need to clean up something) but gawsh, isn't there a middle of the road unit out there that does not cost the world yet does a good job for a Gen X homeowner like me?
The Bryant won't go on for a while:
Being in a middle unit townhome in the Twin Cities this is a comfortable time of year.  I use the Heat-N-Glo fireplace if it gets chilly.  Although honestly I could get by with just that in the winter with the Bryant fan running.
WK78
I've had the upstairs Trane on about three mornings in a row. I don't like waking up cold. I also started the boiler at my dads building today just to make sure everything's ok before it's needed. I left it at 66 in case a cold snap does happen.
I cleaned
the filter plenum, blower wheel, inside the cabinet, and out, then put in a fresh 3M Filtrete 25X16 X5 media filter.
Lenox 2 stage variable speed operating just fine.
I removed all floor vents, and vacuumed them out as far down as I can go.
Saturday morning I lit the gas fireplace for about an hour to take the chill off.  It's that weird time of year when you need heat in the morning and a/c in the afternoon.
I have a spare Aprilaire filter
for the Goodman. Have not change it..........yet. Will probably do so at the EOM. This was I can run it all winter before it needs changed again.
Furnace was running today
when the ultra reliable West Penn power (NOT) had yet another power blip. This is quite common around here. No, weather was perfectly clear around here this AM.
At any rate, the furnace went into lockout mode. After consulting the users guide, I had the option of waiting an hour for it to right itself OR I could throw the breaker for 20 seconds trip it back and that was what I did and the furnace lit right up and continued to warm my home.
Finally, I filed a complaint with the PUC. There's tons of trees in my area that have literally engulfed the power lines which of course makes for rather dicey dependability. West Penn should worry less about investor relations and focus on customer relations.
Last year we had a surge here (no storms either) and thanks to a rotten tree limb 5 blocks away, it toasted 3 AFCI breakers that I had to replace at 37 bucks a throw. Perhaps I should have filed a PUC complaint then but I didn't. Today I did. We'll see what transpires.
No heat here ... except outside.  Temp still running upper 80°Fs and lower 90°Fs.  Nights are getting cooler.  Predicting a norther come through next Wed, drop the daily to 82°F, then mid 70°Fs for a couple days, then back to mid 80°Fs.
Haven't turned on the heat here yet. Usually pretty warm year round with the occasional week or two cold snap. Probably turn on the forced air electric furnace November first and keep the house at 66 and 60 at night.
Hope to eventually get a heat pump.
As far as bench grinders I bought a Sears one as a demo cheap close to 20 years ago and it sharpens mower blades and things like a champ though lately I've been using a 4.5 hand grinder to do them quickly on the mower as I got quite a few working left overs from work as we upgraded to newer versions with a warranty. Not sure who made that grinder but it has all the torque I need and doesn't slow down. Maybe it's US made or a better quality Chinese one than they get away with now.
Shorts and a short sleeved shirt to work today. High was around 80. Low-mid 80's for tomorrow & Wednesday as well. Shorts both days.
I was politely told that I need to wear long pants at my Tues/Wed morning job... Well, if they don't like it I'll leave. I'm not endangering my health. My heart's pumping efficiency is still in heart failure range (although good for another 50 years. Go figure)
As it is I doubt I'll get much sleep tonight. The building's heating/cooling system has already switched over to heating. While I can turn the heat off, I can't change the temp of the water flowing through.
I'm in the Seattle area, living in a place that isn't the best insulated. I've running the furnace since late September. I had hoped to make it to 10/1, but such was not the case. Although it wasn't running much then. It's running more now, although the serious heating probably doesn't begin until Nov. sometime.
I have had the heat on for a couple of weeks now. We have had frost a few nights already. On another note, we had an earthquake last Fri. afternoon at 2:33 pm. I was sitting at my desk and heard a loud boom and then the house shook for 2-3 seconds. I thought my neighbour had cut down a tree that fell too close to my house but I looked all around and did not see anything. I found out later that it was a 3.1 magnitude quake centered about 10 km east of me.
Gary
The DAILY During-The-Day Climate Change!
A/C during the day, to furnace at night, to back to A/C next day, for us, too...
Seems, also, as though mommy dresses Laura warmly every morning before going to school, just for it to be 90° the very afternoon we pick her up...
-- Dave
I envy you guys. We have a Carrier Infiniti System which we had put in last April. (We bought it before they decided to move all of the manufacturing down to Mexico.)
It's been hovering around the low 30's (F) here and the furnace has been keeping up with it quite nicely. We shut off the A/C about a month ago.
We have the system on a schedule.. 72 F normally when we're at home, 66 F when we're at work and 68 F at night.
We had that furnace in the morning / AC in the evening weather about roughly a month ago, but now it has considerably cooled down.
I'm curious to know what'll happen when it hits -40 here in a few months and how much cheaper the utilities bill will be. (We previously had a Carrier Weathermaker mid efficiency furnace.)
