Model: #110-82183110
Serial: #C21914437
Stock: #21831
Remember that 1981 Kenmore 80 Series I took in for repairs at the request of the original owner? I've FINALLY had time to look into it. I've noticed a few issues. First, the 2-port pump is seized. This comes as no surprise and can easily be replaced (relatively). All the other pulleys turn easily and when I spin the transmission pulley the wig wag goes back and forth. The second issue is more troubling.
I put a rug across the front of the cabinet to protect the finish and, not wanting to lay the machine down, tipped the machine forward to the point where it balanced at about 45 degrees, or a little less, and propped it there against the wall. Once tilted, I was able to find the adjusting nut on the back side of the motor and loosen the belt tension to check the pump pulley (seized). When I tipped it forward, however, water came out. I thought that, like my GE FF, the pump started to leak through the bearings, which caused the pump failure. After a few moments of leaking, however, the stream of water turned to dripping oil. I also noticed a light coating of oil on the transmission case and the pump, and it just started to get more depressing from there.
I righted the machine so I could explore some profanity while switching a load of laundry from my '72 70 series to the DE806. Once finished, I tilted the machine forward again to have another look and it leaked water in a steady stream again, then oil in a steady stream, then oil dripping.
I think the transmission needs to be removed, all seals replaced, and new oil put in. I've never worked on a belt drive before and I'll admit, I'm scared of it. I know that addressing the transmission is a big job. I just don't know how to approach it.
I'm going to need to order a Belt Drive repair manual (any suggestions on a good one?) and I'll definitely need any advice that can be given regarding what to do. I have no clue how to take a belt drive transmission out, much less how to take it apart, service it, and put it back together.
What part or parts failed that resulted in this?
Also, I don't have the centerpost bearing removal or installation tools. Will this be a problem?
Thus far, I have not removed the pump nor have I disconnected the hoses to it.
Thank you so much for your help!
Dave
Serial: #C21914437
Stock: #21831
Dave
