"Gray Ghost" Maytag wringer washer - finally!
That is indeed a Model 30...
Hello T,
Congrats on your antique model 30 acquisition! I think they are a fantastic testament to American engineering and reliability of an era long since past. They are built like tractors! Essentially with care, one should last indefinitely - mine is from 1935.
To address a couple of your concerns:
1). The splashing - 180 degree arc in the agitation sounds right. Did you fill the tub to the water line indicated on the agitator? If not, it certainly would splash more than mine in the video.
2). The "drive block" is the square part on top of the post - it is typically loose, and in fact, if the machine is running without the shift lever engaged, and the agitator is removed, you will notice the drive block actually moves ever so slightly back and forth (in spite of not being engaged.) As for the rounded shape on top, that is the design. Personally, I wouldn't mess with it.
3). Removing scale on the washtub and agitator - I used SOS pads followed by fine-grit sandpaper. Then, fill the tub with extremely hot water and add a non-corrosive / non-oxygenated detergent (such as Original formula Tide). Agitate for a few minutes, or for that matter, do a load of whites while you're at it.
Periodically, I would suggest polishing with "Mother's Mag & Aluminum polish" - it is amazing for polishing the crown and agitator to a mirror-like finish.
Brad: Help Refurbishing a #624979S Model 30
Thanks so much Brad.
It's raining today, so in between downpours and a during a brief peak of sun I went to evaluate the washer per your information.
Started machine without agitator - Drive block moved about 180 without being "engaged" - more than slightly moving lol
Filled washer all the way up to score line on agitator - No splashy :)
Washed a few towels - tested wringers... not bad, still need work.
emptied tub
removed agitator - Drive block did not move at all unless "engaged" this time.
Now I am befuddled. My husband fears the pin inside or something is broken.
Since it "works" I think we'll just return to THAT issue later. For now, I'm just gonna keep cleaning etc. Tonight we replace the motor cord and plug. Wish me luck.
I'll check in soon with some progress and more questions.
Thank you much.
