HA806 Lives Again!
Gobsmacked, Alex?
I had to look that up, but having done so, all I can say is thanks, that's quite a compliment!
Now then, Patrick and Malcolm, I agree completely that repainting a cabinet can make a huge difference in the appearance of a machine, and bring a restoration up to a whole new level. Frequently, the porcelain top panels on vintage machines survive in very good condition, while the rest of the painted cabinet truly shows its age. Sometimes careful use of rubbing compound can restore faded paint to its original color and shine, but when it can't, painting is the only option. The cost of the materials is pretty well fixed, so there isn't much any of us can do about that. But if you have the space at home(I don't)to set up a simple spray booth, you can save the cost of having the paint applied. Obviously, it's not worth the trouble to do this for one machine, but if you're one of those folks(like many on this blog)that always has a project going, then you may want to consider it. I used to work at a place that did a great deal of work on corporate jets, including painting. Though the shop often did entire paint jobs on these aircraft, most of the time they were repairing damaged paint in one particular area. To prevent the over-spray from going everywhere, they would construct a framework of PVC pipes around the work area, and wrap it in plastic. These structures were sometimes large, but frequently small, and as I watched them setting one up one morning, I couldn't help thinking how easy it would be to build a framework of PVC pipes that would form a small spray booth for home use, and could be folded away and stored when not needed, perhaps even folded up to the ceiling of a garage. Then a small rotating platform could be made using plywood and some common pipe fittings so you can turn your project instead of walking around it. Just add a spray gun and a compressor and you'd be ready to go. If I had the space I'd be very tempted to try it.
Great restoration job. She looks beautiful! I have a Frankentag the cabinet tag says it's an 806, the tag on the control panel says it's a 606, so I really don't what model it is, it's harvest gold as well.
