Halo of heat dryer
The cycling thermostat could be bad or the high limit thermostat is getting weak. Does it take multiple cycles on permanent press or does it take a few cycle to dry on the other cycles?
The Permanent Press cycle dries at a higher temperature than the regular cycle. So I would guess the high temp limit t-stat is weakening.
Do you know if you can still get the hi limit stat and where is it located? Do you happen to know the temperature s for the reg cycle and perm cycle? Thank you for any information and help you can provide
DE-406 MT HOH Dryer
If it works on regular just use regular, the only difference is regular has a 3 minute cool Down and PP has like 7 minutes.
There is only one operating thermostat on this dryer, both cycles have the same temperature, if it really does not work on PP you have a bad heat contact in the timer and you need another timer.
