mark_wpduet
Appnut
so basically are you saying that your Duet uses as much water as mine, only in the other cycles? So your Jeans cycle would use as much as my normal/casual etc? On any of the cycles on my Duet (other than the clean washer cycle) the water never touches the glass - EVER! Not even on delicate or soak.
Also, on my normal/causal, it does do medium drum rotation but it only fills with more water at the very end, like a minute or so, that's it; it drains from there..To me - that doesn't count, since the main wash is over anyway. But the main fill is the same as heavy duty/whites whites/Sanitary. They all use the same amount of water from what I can tell. I also notice the Sanitary fills at the end of the wash too, like normal casual does.
