launderess
"The iron is the small appliance that uses the most electricity."
True, but much would depend upon what sort of iron one was using (steam or dry) and type of ironing being done. For latter that is ironing damp laundry dry versus using a steam iron on dry laundry.
Steam irons use energy two ways. First to heat water converting it into steam. Second is to heat soleplate which helps with ironing but also to some extent dries out steam coming from iron.
If one is ironing damp laundry soon as soleplate meets cold or cool textiles it will there will be a decrease in temperature causing heating elements to power on. This will occur with both dry and steam ironing.
Back in day housewives and others were advised if they couldn't get to their damp ironing right away to put things in refrigerator. Well that works fine for slowing down or preventing mildew, but if taken straight from fridge and ironed those cold textiles are going to do a number on iron. Latter will have to struggle in order to keep soleplate at proper selected temperature.
Dry textiles still will reflect ambient temperature of area they were kept in, but you don't have the effect also of moisture/wetness which acts to cool surfaces.
