HE top loaders
Well, I have to admit that I am sort of surprised to know that. I also know that you have no reason whatever to say that if it were not the case. I have had great success with my front loading LG made machine as well. How does it compare to a traditional top load washing machine though? Does it wash and rinse as well as, say your old speed queen or Kelvinator washers? You don't sell appliances for a living or have any reason to be bias about it, so I would trust your judgement.
You're right, I can't imagine how clothes could get clean in a pint of water either. Good thing HE top loaders use wayyyyyyyyyy more than a pint of water. Seriously? :-/
Gansky-- I love the look of your LG. Reminds one of the earliest top-loaders with controls along the front edge-- Maytag, Whirlpool, Frigidaire and Blackstone come to mind.
As mentioned upthread, the newest HE top-loaders appear to do a much better job than did the first generation of these machines. Your LG is rated highly by CR after the correction of a software issue that had to do with handling unbalanced loads.
Using an HE Top-loader:
1. Load the machine according to instructions in the manual.
2. Use the proper amount of a high-quality HE detergent.
3. Select the proper cycle for load being washed.
# 3 seems to be the most difficult issue for many HE users. Some are always looking for the cycle that uses the most water, which, as you pointed out actually decreases the machine's effectiveness. While it is counterintuitive to many, using more water causes rather than solves problems concerning cleaning power. If you can't bear to watch a washer that uses comparatively little water, then set the controls and walk away until the cycle is completed.
HE Top Loading Washers
Don't use a pint of water, or anything close to it, in fact they use more water than most FL washer cycles, so if its MORE water you want you guys should be trying out these interesting washers.
We have had several Samsung and LG TL HE washers come through the shop in the last few years and we have always resold them after a lot of testing and playing with them and they do a pretty good job overall.
I do think with HE TL washers it is more important to select the correct cycle for what you are washing and sort the clothing for best results, FL washers are more forgiving about what you throw in a load.
Greg I am glad you are having fun with your new washer, I will be interested in hearing a full report, is the one you got Chinese or Korean manufactured ?
Apparently you have to pay strict attention to HOW you operate these machines, but a front load machine still has it all over a top loader now for lint and sediment removal and they do not create any lint either by agitating or in this case with the impeller. Just easier for them to get rid of any lint or sediment of any kind than a top loader. I may not have used the one we had nearly 20 years ago properly. It did tangle badly with a big load of jeans or cotton pants. I know it was a foreign brand and the case and top was all plastic. It may work ok, but I still say a traditional top loader like a speed queen would have to do a better job and a front loader even better with less water. I hope LG got the off balance problem under control. LOL I would hate to come home to find my washing machine had caved in the sheet rock! LOL
OTOH, gimme a top-loading dryer any day!
I'm enjoying this thread. For the most part, it has confirmed what I have believed all along: plain old physics suggests that a front loader, using gravity and a comparatively small amount of water, keeps the dirty laundry moving and soil emulsified and suspended without a lot of idiotic mechanisms and BS. Even better if the machine has an internal heater.
These arguments also connect to a previous thread that indicates that Americans have a strong preference for anything Top-Loading, most probably because that's what their parents had. I know one friend who's no dummy who chose an inadequate contemporary Top-Loader because "that little porthole that I'm supposed to stoop down to load and unload the machine would drive me crazy". I think for most consumers you put the clothes in the machine, add the prescribed products, push the button and at the end you've got clean clothes. I don't think most people these days really care if their laundry is as clean as it could be.
To paraphrase Crystal Allen: " If you throw a blouse into a working washing machine, what's to keep it from getting done?"
I must admit, even though I collect and covet all my vintage Top-Loaders, I use them less and less as daily drivers, especially now that I have the Miele hooked up and working. It's superior in every way except capacity, although, for my needs, there are very few loads that need to be done in the 1-18 and it's beginning to show signs of age. I can load the Miele with laundry and all the additives needed and walk away from it knowing that in 24 short hours (kidding) my laundry will be as clean and as damp-dried as can be.
A couple years ago,
these had a max. capacity of 3.6 cubic feet. They were belt driven, with a celcon splutch gear drive case. A mode shifter actuated the springs engaging the gear case to agitate or to spin, so the entire basket doesn't also agitate back and forth. The motor reverses for agitation.
The new models elimninate the belt, but have the same drive system. Now the motor mounts directly to the bottom of the gear case and input shaft rather than a pulley for a belt.
Mine failed after four years. The seals wear, and water gets into the gear case and bearings.
All I can say is my LG made front loader holds more than any washer I have ever had and cleans it magnificently with no lint, sediment or wear to the items being washed and spins it nearly dry.
That was part of the reason of getting a Filter Flo because I have 2 cats and lots of hair! That thing collects most of the hair/lint even before it goes in the dryer. I got better results from the Kenmore 28102 with that than the LG front loader I used for 2 years. It didn't get rid of the hair very well at all.
I cannot attest to "hair" problems. I do have a dog, but the reason I picked that breed is because they don't shed. I don't have a lot of hair in my laundry, so it isn't a problem I've ever had to deal with. I can see how a machine with a lint filter might be helpful if you have animals that shed.
