windrivers
speed queen perfect wash
The Speed Queen TR series has the same capacity and apparently uses the same tub and basket, so until someone can verify, I assume a full fill would use substantially the same as the TC.
It still isn't clear to me exactly what the resource saving advantages are of the TR series. I know John has made the claim that, even though the TR has a motor that advertises twice the hp of the TC, it uses 1/4 the energy of the induction motor used in the TC. Even assuming he means for the same power output, it still doesn't seem to add up. (https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?92925_75 Reply 70)
As I recall, a typical induction motor has an efficiency rating well into the 90s which would seem to mean that the motor used in the TR would have to have an efficiency rating of over 360%, which I don't think stands up to reason or physics.
It must use less hot water by tempering the temperature as I understand that is supposed to be a big factor in energy use. Again, maybe others can verify.
