Help choosing which one please???
I just don't know! One of my friends a Whirlpool Inspirations AWM 328. It is a good washer but the balancing is sometimes stupid!
The second Whirlpool I have never seen it in action in real life but i think they are quite reliable.I am not sure.
The Asko is supposed to be very reliable but i dont know about wash performance.They are a bit noisy i think.
The Bendix looks cool but I have never seen that one before!
Hope this helps!
I would opt for the Bendix, because it looks like it is built heavier and more solid. I look for large induction motors and commercial reliability in these machines. You want both a stainless steel inner and outer tub. Plastic is something to avoid if possible. Spin speed is not as important as quality construction, and you can always buy an extractor. I learned all this from an old Italian machine I found recently. It sat outside for a good while, and was rusted in places. All I had to do was re-fasten the boot and it runs perfectly fine!
By the way: Some may think I have converted to front loaders. I haven't. Every machine has its niche, and I find mine to be good in some areas, while my top loaders offer advantages in others. Anyway, good luck and I look forward to reading about your decision.
NorfolkSouthern
Oh I would go with the Bendix Duomatic as well, looks like a great machine!!! Wish we could get those here in the states!
I agree with Mike, of those three the Asko is the best. I would love to play with one of those Bendix machines, but you don't see them very often overhere. Around ten years ago they were sold overhere in the Netherlands but after a while they disappeared from the market. Have never seen them in Germany. I'm surprised they now turn up in Australia, it's an older design.
ASKO.I've had a few that the customers discarded and they,once repaired,worked great and did tons of wash.None of them had major issues.One needed a new belt,another needed a new panel (just the frame not the electronics) and another needed the button catcher severely cleaned out.It was blocking the flow of water out through the pump.
Would go for the Bendix if I were you, purely 'cos it looks like a real solid machine. However, based on the info in this thread about the Asko and if you want a machine that stands the test of time, it seems like a no brainer, to quote a previous poster!
ASKO
...which was previously known here as ASEA and then ASKO ASEA. Mum updated hers when it was 19yrs old and it was just starting to give timer trouble (slow to start...but then ran fine). That particular machine is still going strong at a mates who has two young children.
Out of the ones you have mentioned, it is the only one I would go for.
Bendix are quite lightly built (doors, drawers and switches) and the Whirlpools don't have the best reputation either (particularly with rust)
Go for Asko
Both ASKO and Bendix are owned by Antonio Merloni CO
But Asko is still made in the swedish works, while Bendix is just a glorious name of the past printed on a cheap machine (still made in Italy ?).
In the last mont I have used a Bompani machine (otherwise badged as Philco, Bendix, Equator, EBD, Servis ...). Not so bad in washing, but extremly weak built.
Whirlpools : the older series (AWM312) is said to be slightly better than the AWM8121. But it's a Whirlpool anyway ....
Hi Josh, I am guessing you want a machine for fun, rather than do all your families washing on a daily basis?
If thats the case, go for the Bendix. I used to have one and it was a fun little machine. It still looks stylish, and it has a tendancy to tumble in one direction for a long time, then reverse for a short time. However the cycle does go on and on.
What ever you get, have fun!
Asko
Hi Guys.
Does the Asko machine have a cast iron drum cradle, looking at the pics on here, it looks like it has a cast iron drum cradle
Paul.
Go with the ASKO
Stay away from Bendix and Whirlpool. They are nasty. I personally know two people with the Whirlpool AWM8121 and neither are satisfied with their machines. After only a couple of years both washers have developed significant rust issues and they don't perform all that brilliantly either. I've attached a link to 'Product Review' for your reference. Whirlpool front loaders don't rate very highly in most consumer reviews. Bendix isn't even on the list. Thus, consider product support and the availability of spare parts.
Years ago I made the mistake by purchasing an Italian made Bendix dishwasher. That was the biggest piece of shite I've ever owned. It lasted two years and nothing Bendix will ever make it into my house EVER again!
Now, this is not a lecture, but consider carefully what you buy and why. The vast majority of front loaders on sale now are throw-away items designed to only last five or six years, if that long. You will be lucky if spare parts are available three to four years after purchase - should anything go wrong. It doesn't matter whether you buy a BoL, MoL or ToL model, price does not any more reflect performance, quality and/or product support. None of these machines will save you any money or the environment.
ASKO has a good reputation and rates much better in consumer reviews. If I were forced to purchase a front loader I would go with ASKO or Miele - but luckily I don't have to. I'd rather stick with my Speed Queen (Kleenmaid) top loader.
Hope this helps
Rapunzel
http://www.productreview.com.au/category.php?cat_id=1041&section=ITEMS&manf_id=1029
I own a similar whirlpool to the AWM 312. It is OK but they have a nasty fault, the drum spider is too lightly built and it is prone to corroding and snapping. You cant get a replacement spider, you have to buy the whole drum at over $350. Śo avoid that one.
I dont really know the later Whirlpool like the 8121 but it looks just like the earlier one with a new dashboard so I would avoid it too. Whirlpools have very long cycles by Australian tastes, too.
I have repaired one of those Bendixes, they are OK but there are no spare parts for that model now. They were made by Philco in Italy, they dont exist any more. (?) The quality is OK but nothing special, prone to rust in the cabinet.
An absolutely terrible machine to work on, access is awful. Avoid.
I would highly recommend the Asko. I own one and have repaired a couple, all older than the one in your photo. The 10505 was a problem model, it was the basic model at the time. If it is not a 10505 (or 10506??) then Id buy it.
(Sorry about the lack of apostrophes - keyboard trouble.)
Chris.
Sup guys thanks for your feedback, I just won a whirlpool AWM295/1000
haha pretty happy so now i dont have to hold the door on the whole cycle. but you all know ill miss my "Hoovie" haha
cheers
Josh xx =]:
Hi Josh
to keep your Whirlpool in good condition, make sure you use a reputable detergent (no mystery buckets from the $2 shop) and dont wash in cold water. That machine is one of the models with the drum spider problems, so you must be careful that your washing technique doesnt leave detergent residue accumulating inside the drum. That means - only good quality detergents, and warm or hot water washes.(minimum 40 degrees C ).
as long as you stick to that regime, and as long as the previous owner washed OK, then you should be fine.
Best Wishes
Chris.
faaaaaaaaaaaar out man i just checked the spider. if it hasnt been used for a few hours, when you turn the drum it cracks once nd just sounds like the motor noise/ im scared i sw a pic on here with the washing machine drun sticking out the top and now im freaking out about my whirlpool. aaaaaaaaaaaaaah im gonna tke it down to my mates at the repair shop just to be safe
what are common signs of this stuff happening?? i really need to know nd id appreciate it heaps.
* FIVE ALARM FREAK OOUT*!!!!!!!
signs of impending doom -
minor - open the door, turn drum till one of the paddles is at the top. Try to rock the inner (stainless steel) drum up and down. Then turn the drum till the next paddle is at the top, and repeat. Then turn till the third paddle is at the top. repeat. If the drum moves differently (more or less) in any particular position, or if it makes grating/cracking sounds, it might be the spider. (if it has a bit of slack but it is even all round, and rumbles when you spin the drum by hand, it is more likely drum bearings.)
Major - if the machine makes awful banging sounds, or harsh clacking sounds on spin, particularly if the spin is out of balance, then it is likely the spider.
It is unlikely to bust out the top if the spider fails completely, more likely to make an incredible noise, and grind to a halt, possible smashing up the plastic outer drum, detergent dispenser drawer and other internal plastic.
If you create a deliberately unbalanced load, for example by spinning a phone book, you can listen for any horrible noises. That is a pretty severe test so if it spins without sounding like it is going to self-destruct then it is probably fine.
Chris.
Thanks Chris
Iv'e been without power for 3 days and its finnaly on. haha i only did two loads and lost the power. ive got it on now and i did what you said to do the day i got it. no problems. it has a bit of slack but my other whirlpool did that too and i never had a drum problem with it. the worst i get is the rubber making that nasty gunge noise when its out of balance.
Detergent wise I use omo matic, surf matic, Bio zet for frontloaders and radiant matic. I dont do half scoops unless its a half load and once a month i put the machines on cottons 95 with a morning fresh tablet in it and wipe anything else down when its all done.
am i doing anything that could cost me heaps????
Heres a pic of what its doing now. all tucked in and just "kickin it fresh"
Get yourself
...a dryer mat...
It'll reduce the noise and mean the dryer can't move at all...
...they're normally available from Harvey Norman, Retravision etc...and are made from recycled tyres...
