Help - difference between GE Washer clutch part numbers
delco1946
Nov 24, 2022
197
Oregon
Can someone tell me what the difference is between GE clutches WH49X265 and WH49X198? These seem commonly available, however none look exactly like what I have.
I need a two speed clutch; I'm thinking newer stock may have changed/replaced the original parts.
Full Story - a shop broke the inner drum so I need a replacement. However, i'd rather spend a little more and get all the other parts that come with a NOS assembly, rather than just the inner drum. My 57 1WA850 is dead in the water until I can get this fixed.
GE two speed washer clutches
GE made a lot of changes in those clutches from the time they were introduced till the later ones yours is among the first two speed clutch I believe in 1957
I’ve not tried it but I believe it may be possible to install the later two speed clutch it has a different shift actuator and you might have to figure out how to mount it to do so, if you can put the later clutch in, I think you would be smart to do it because they had worked out a lot a little bugs with it.
Personally, I would be very tempted to just throw a one speed clutch in your washer, there’s very little use for the two speeds if you’re not washing a lot of delicate dainty stuff in the machine .
Even on later GE we frequently just threw a one speed clutch in when people had problems. Those are readily available still.
As to your original question, I could maybe help if you posted good pictures of what you need to fix the old clutch
John.
Yep, it sure is. Did this with the '58.
I would highly recommend getting the WH49X265 kit and using all parts from the kit, with the exception of the carrier plate, or at least I hope the carrier plate is fine and it was the primary/inner drum that the shop broke.
This way, you can use the original style solenoid brake shoe on the '57, vs. having to make the changes I did to swap it over to the "finger" style on the '62 and later clutch.
Ben
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?82804
Cooking with gas!
Thanks John and Ben!! This is very helpful. I’ll order the x265 kit. My carrier plate was fine for now, but I am a little nervous they might deform it. But I think the young guy helping me learned a lesson with how to support an item while pushing the bearings thru. They had brand new bearings so I think I might be better off using those versus ordering the x91 bearing kit and getting 30 to 60 year old grease, which had probably started to break down.
Went gung-ho
I bought the Wh5x207 and the wh49x265 just to be safe and have backups. This also has me thinking it might be worth just buying a bearing press machine from harbor freight for $169 so I can do this myself in the future. I’ve had to do this enough times now where a hammer the right size socket isn’t cutting it.
Hi Ben, regarding the clutch, the nos one still seems much quieter/ smoother to spin than my rebuilt original one. I reassembled and relubed the motor and replaced the clutch bearings. The old clutch also seems to sit cocked on the motor shaft for some reason ( which I’m sure creates a lovely spinning imbalance). I hooked up the washer and the old clutch works but is rather loud, especially on slow wash ( rattles like a can of nails!). Otherwise everything seems to work.
At this point, I would like to use my nos clutch, but I’m not sure how to modify it to work. The only major difference is the carrier plate which exists on the old version, but the new one just has little old dog ears that stick out, which would be incompatible with the original style braking mechanism/ brake shoe. However, I am wondering if those dog year tabs have just the right amount of mass to trigger breaking without an accessory brake shoe? If it’s as simple as disconnecting the brake shoe that almost seems to easy to be true. I tried transferring all the guts from the new one and using the carrier plate but because of subtle differences in washer spacing and design, the carrier plate does not spin freely, and I can’t add washers to make it spin freely as that increase the height of said stacked pieces, and can’t clip on the O-ring clip on the very bottom side 🙄.
What sort of modifications did you have to make?
GE washer two Speed clutches
I would use the new style to speed clutch and try to mount the little shifter solenoid from a newer design one on the motor mounting plate. I don’t think it would be too hard to do.
Just grab a two speed clutch and motor assembly from a newer filter, flow washer And you can see the difference and how to mount the shifter solenoid to work with the newer style clutch on your machine.
It’s very hard to rebuild old Worn GE clutches and get them to work quietly. Also the older breaking mechanism they used on your machine was not a very good design, which is why they changed it if somebody accidentally turned it onto low speed while it was running, it burns up the brake shoe.
John
Hi John,
Are you saying that newer filter flows added a solenoid that somehow activates the tabs where on older clutches the carrier plate is? Are there pictures of this somewhere? Im guessing it’s a separate part that I could buy on eBay once I get a part number? I’ll do some digging.
Took a picture on the underside on my nos 2 speed clutch with the tabs if a picture helps.
Thanks - Christopher
In my thread I talk about replacing the brake shoe solenoid mechanism with the tab solenoid shifter bracket. I had enough parts on hand from salvaged clutches to adapt the shifter bracket to the ‘58 motor plate.
I had to go this route as I had damaged my carrier plate, but even when I had tested the machine prior to disassembly it was noisy and ultimately I like the quiet sound of the swapped finger style clutch.
Ben
If anyone knows this shifter solenoid part number, that would be helpful (or of course has one to buy). I haven't found in in the master parts catalog yet and nothing resembling it comes up with internet searches. Based off John's description and the fact that this was the prevalent (later) style for GE washer shifting, I would think they are somewhat common...?
AFAIK, GE didn't sell the full assembly for the shifter assembly but rather sold each part individually.
I have seen the shifter assembly sold with a full retro kit to swap out a full motor/clutch assembly (WH49X271), however this kit wouldn't work on your '57, unless you bought one just for the shifter.
One option you do have is something John mentioned earlier. You could always put a single speed clutch on the washer, or throw your original clutch on it and live with the noise.
Ben
https://www.ebay.com/itm/283749185795
Later, GE filter, flow to speed clutches
Here’s a picture of the later clutch assembly that was used from 1961 through 1994
The little magnet assembly was available as an entire assembly. That’s normally the only way we ever saw them early on you could buy it piece by piece.
I should think it would be fairly easy to use the newer clutch you got, and to buy this little shifter assembly and mount it to the mounting plate of your old 57 GE washer.
John L
Chris, I take back what I said on 3/11. Tonight I stumbled across the PN that GE later on assigned to the full shifter assembly - WH12X847. There are several out on eBay and available through other vendors.
Ben
