oldschoolmeg
I've been testing the juice in a pickle jar in the fridge regularly and it started off at 35 deg and this morning it was 37 deg. I have an expensive thermapen instant-read so I'm confident that my measurements are correct. I'm thinking now a leak just because if it was left alone overnight it should've at least been the same temp or lower in that pickle jar. I've been keeping a stick thermometer in the freezer compartment to keep up with temp there. I don't have any ice cream or anything like that in there at the moment. It was staying around 20 deg every time I checked that.
I've asked some other people on a thread and they acted like replacing the compressor with a modern one was downright sacrilegious. But maybe they are a little biased. Whatever is best I will do. I am a little skeptical of putting an equally likely to fail older compressor back in this unit.
John--are you suggesting retrofitting a new compressor onto this? Along with replacing the need for R-12 with R-134? Like I said, I have no apprehensions to a complete retrofit or replacing with a similar older model, as long as it works and continues to for a long time.
