This KA was purchased by my parents around 1974. Because of its longevity the sales experience has become legend here... they asked for a GE and the salesman said, "What would you want a GE for? These are much better"- and the rest is history. I believe my parents replaced the fill valve and timer long long ago but it didn't need a fill valve. The repair man got the diagnosis wrong. I pasted some sealant around the fill switch port when I saw it was rusting ~1990. The base of the hub of the washer arms was cracked but we knew someone with a similar model who was buying a new DW and they swapped arms for us before their new one was delivered. Other than that we have done nothing to it. It is rarely used.
Recently I tried to use it. While the pump is running there are a few drips which hit the top of the motor fan but if you shut it off with a full load of water you get a deluge. Correct me if I am wrong but this strikes me as a bad impeller seal because as the impeller spins it will create negative pressure on the seal possibly leaking air in to the water it is trying to pump but once off, gravity has its way with the water. I could not remove the impeller to inspect underneath. I don't know if it is threaded or splined and I don't want to bust it. It seems to be made of rubber.
I am totally up for suggestions as to what to do to preform a proper repair ie 'while you have that apart you really should...." because without a forum like this I would have no idea what the Preventative Maintenance items are on this museum piece. I would have ordered "KitchenAid KD15 KD16 KD17 Dishwasher 102577 Impeller Seal Kit AP3101837 4160551" on eBay and hoped:
A- this is the part I actually need
B- I can figure out how to get it in there
C- with no clue as to what else should be done 'while I'm in that far'
D- without knowing any caveats as to what is easy to break / get wrong in performing the repair
and the like
I have read as many forums here as I could find on the 16 and thought I'd ask why in the world this one does not have a heating coil. Every other one on here has a coil. When I used this washer years ago I remember turning the gas hot water tank (it's only 30 gal. anyway) all the way up and waiting a half hour to start the DW. I could turn it down then when I started the DW. That seemed to work.
I have other museum pieces I must share with you all. A 1961 Kelvinator range and dryer. Doing so will need to wait until after this is DW running again.
I love buying quality and running the wheels off of it. Unfortunately that means I drive a rice burner but I digress.
The link I attached in the posting form is a link to the only pump diagram I have found. The resolution is not the best. I assume the impeller seal kit is #18 on this diagram.
The blue steaks on the inner door is soap from the aborted run. It is not permanent.
I thank you all in advance for any tips you have to share!
PS anyone stumbling around the web looking for miscellaneous KDI-16 info must stop by here. This page is #1 in info on this unit I have seen anywhere
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?45367
http://www.partselect.com/Schematics/Whirlpool/SYV5BAWK.gif
and the like
