I have gotten the inner basket out of my 1959 Kenmore. I ended up taking a welders torch to the flare of the spin column, while alternating a spray of WD-40, and then quickly jumping up and down INSIDE the tub! Hey, whatever it takes. Anyway, I was shocked upon removal of the spin basket to find the center post of the outer tub flaked with BIG chunks of rust. I got busy with a wire brush and cleared the area of most of it and vacuumed it away for a better look. I am not seeing any pin holes in the center post, however where the center post meets the center post gasket at the bottom the rust continues out of sight underneath the gasket. ALSO, of the four bolts holding the outer tub onto the platform, two of them showed rust. The one at the 9:30 O'clock position was the worst the next worst was at the 12:30 O'clock. In both of these cases the little rubber washers underneath the bolts are showing rot. The area around the suds-return drain (on the side wall of the tub) looks alright. The area around the tube for the water level sensing looks alright. The area around the sump opening at the bottom of the tub LOOKS alright, however there is a plastic "wing" on it (water deflector?) that might obscure a problem unless removed. and it is not lost on me that the tub to pump hose COULD have a leak in it (however, when I recently changed to pump out for a new one I inspected those hoses and they seem fine), BUT the leak I am chasing is dripping water on the platform on or about the 7 o'clock position.(Or it could be like a leaky roof and is comming from the centerpost gasket and is running down to the 7 O'clock position before dripping off of the platform!) There is evidence of rust build up over time in this area. Now it does not escape me that both the drain for the suds-saver, AND the sump to the pump are both in this area. So here are my questions regarding the problem of the leak. 1. Should the outer tub be scrapped altogether? If not, Should I attempt to remove the outer tub to replace the old washers around the four attachment bolts, AND/ OR the center post gasket? Or can I simply coat these areas with a heavy layer of Hi-Temp (Automotive) Silicone Liquid Gasket to seal them? How do I put a stop to what seems to me as a potentially catastrophic rusting of the outer tub center post? Is there some kind of rust-o-leum product I can paint it with? I will go into a holding pattern for a while to give everyone kind enough to respond to accumulate a bank of information. AS ALWAYS I am most GRATEFUL for ALL of you and your kind advice!!! -Steve
