thatwasherguy
Hi there! I have a 1978 Maytag A-208 that I am restoring. Internally, there is very little rust. However, there is rust in the worst possible place: the outer tub. I would just patch it, but it is at the top where the two pieces of the outer tub connect. I had noticed in the tests before I took it apart, that it was leaking, and that the water level only dropped about a half inch or so. A leak from that seal would explain why. Do I have to replace the outer tub, or can I patch it without it leaking? If it has to be replaced, does anyone have a spare? I’ll be at the storage unit that the washer is in tomorrow to get some pictures of the rust hole so you can see what I’m talking about.
Thanks,
Thatwasherguy.
Thanks,
Thatwasherguy.
