patpackrat
Active member
- Joined
- Feb 25, 2005
- Messages
- 26
My 1977 Maytag CA408 washer recently lost its ability to brake after the spin cycles. An authorized Maytag repairman whom I've used in the past for repairs on a couple of other appliances, told me that with a washer as old as mine, replacing the brake mechanism is like "opening a Pandora's box" -- one part replacement leading to another -- and said (surprisingly to me) that I could go on using the washer with no adverse effects, which I did for the past couple of months. However, the other day a load was finishing and I heard a couple of screeching sounds and then smelled 'rubber burning'. I went over to the washer, lifted the lid, and realized that although it had pumped most of the water out, it had stopped spinning and the tub had seized. So, once again I called my 'Maytag repairman', who basically said that machines this old are all corroded, rusty or whatever and when you take one part out, another breaks. He said I would just have to buy a new washer because he wouldn't fix it at any price! Well, the problem isn't that I'm too cheap to buy a new washer (though I know they're not $300 anymore!); the problem is that -- aside from having no respect for or faith in anything new -- the washer is in my kitchen next to its matching dryer and among all my other 'vintage coppertone' appliances. But, in the words of the Maytag repairMEN (I spoke to another one), after 27 years of service it's life expectancy has more than been met! Something's wrong here -- why are they making parts for these washers if it isn't practical to repair them???
So, like someone just diagnosed with a terminal illness and in denial, I turned to the web, seeking either a ray of hope or agreement with the diagnosis, and I happened upon this site! After reading through many, many of the posts here, it seems there's a wealth of expertise among you guys, and I feel sure I can trust your opinions, negative or positive -- if you'd be so kind as to offer any.
Thanks so much,
PAT
Thanks so much,
PAT
