gearjammer
- Joined
- Jan 7, 2006
- Messages
- 5
I have a standard top loader Kenmore washer...circa 2000. Fairly often it will just skip the high speed spin portion of the cycle.
Could be either of the two high speed spins...usually though it's the final....of course the clothes are soaking wet as a telltale....When it does this...the motor runs..but the tub just does not spin. By pushing in the knob on the timer/selector [turning machine 'off'] you will hear a loud snap and the tub turns slightly...sounds to me like something all of a sudden, is engaging...
then if you pull the knob back out the machine works properly.
I don't have the expertise to determine if the problem is in the timer...[ or a relay?]or the transmission is just stuck. Either repair may be a bit pricy. And on a $400 machine, 7 tears old, should I perform either repair?
