Hi everyone, I have a F&P single dishwasher draw. It is not pumping water out. I have taken the filter out and pulled the impeller out of the bottom and no blockage that I can see.
When I try to force water down the end of the drain pipe there is total resistance. Is this resistance a blockage or is there a valve system in the pump that opens to pump out?
I have pulled the draw out and put it on its side. There is a plastic cover which I am having difficulty to remove. I figure if i can get the plastic cover off I can disconnect the drain hose from the base of the draw and check for blockages.
I am also not sure if there is a seperate drain pump or if it is an all in one pump/impeller that sits in the bottom of the tub where the spray arm sits.
I am having difficulty getting technical information or schematics on the internet.
Any suggestions would be very welcome.
Cheers
Simon
Cheers
Simon
