Hello all,
I found this site while searching for info on my machine.
My machine is labeled as an "RCA Custom 60"
PLate says:
Distributed by RCA Limited, Montreal, Canada
Model WAA600
Ser#757325
110v 7.5A 60cy
The similar dryer is shown in this thread:
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?45474
I've been using it since I got it for free back in the early 90's
The original owner thought it died and left it behind in the place I was renting back then. The belt had been replaced with one the wrong size and it was too tight. I changed the belt and it has worked ever since.
Unfortunately it stopped draining a couple days ago.
It fills up, agitator works, but it doesn't drain.
Motor is running when it should be draining.
The agitator is stopped at that point so that seems to be working as expected.
If I bail out the water, it will spin.
I'm looking for a manual for it, or even one with a similar configuration/transmission.
I figure I can simply strip it down and figure out how each mode works, and check all the wiring, but a manual will help fill in all the details.
Like.... should I change the oil ? Anything else I should service at the same time ? Should I even bother ?
I love the fact that this machine was running all these years, and I hate to see it die.
Not to mention that the idea of buying one the current POS machines, which seem to be designed to last 6 years, leaves me cold.
Anyone have a manual or know where I can get one ?
Any other suggestions ?
Thanks very much in advance.
PLate says:
Model WAA600
Ser#757325
110v 7.5A 60cy
