rollermatic
this capacitor is off my 1965 rollermatic model wcda-65. one of the terminals broke off causing the washer not to start up in either spin or agitate mode. when I bypass the capacitor the motor starts fine which tells me that the faulty capacitor is the problem.
this washer must have the capacitor wired in series with the starting winding for it's spin mode. it was one of the first rollermatics and used the type of clutch that did no slipping under normal use. the motor is directly coupled to the tub thru the rollers and as the tub builds up speed so does the motor. it takes about 17 seconds for the motor to gain enough speed for it's starting windings to cut out under normal use.
I thought about soldering a new terminal (or wire) onto the capacitor but there is also oil that keeps oozing out the top, I'm assuming the capacitor must be replaced.
I could change out the clutch with one I have from a later model that used the slip type clutch allowing the motor to start immediately and gradually bring the tub up to full speed thru the action of the clutch. I have one but it goes to another rollermatic I am in the process of restoring (a thread on that restore will be posted soon). plus I would like to keep this machine working as it was originally designed.
the capacior is a delco 125 volt that says it is 124 mfd. it's about 3 inches long and 1 1'4 inches wide.
I understand basically what a capacitor does but do not know what 124 mfd means. nor do I have the first clue as to where to find a new one that will work.
any help from you appliance pros will be greatly appreciated.
