bootsnslicks14
I could use the help of some experienced Maytag experts.
I got at least a couple issues with my A702 Washer.
First being a water leak, I have circled where it's leaking from and attached a picture. I'm not sure where it's originating from..
Second issue/s seem to be electrical related.
I'll try to explain best as I could..
Sometimes during a cycle, the machine will just stop and I'll have to tap on the lid or control panel to get it going again..
Also, when the final dry cycle is finished, I have to physically push the knob in on the center dial, otherwise it will start filling the tub again even if it's pointing to the "off" position. I have already replaced the inlet valve with a NOS stock one so I know that's not the issue..
Thanks for reading.
Thanks for reading.
