Help with KitchenAid dishwasher
gadgetgary
Bronze Member
Jan 31, 2005
3,867
Bristol,CT
I received this email today and wondering if anyone can help,
I'm sorry to bother you with my problem. I emailed Robert about a problem I'm currently having with a "newer" model KA dishwasher. He suggested I post it in the forum however I'm not a member and didn't want to have to create a profile and enter all sorts of info and then just end up deleting it. If you could be of some assistance I would be eternally grateful. So here it goes:
I happened upon your site a while back and I enjoy popping in and looking at the treasures people find and the awesome restorations done on older appliances. I have a fascination with vintage appliances as well and have always been fascinated by washers,dryers, dishwashers and microwaves since I can remember. I was wondering if I could ask a question about my dishwasher. I have a KitchenAid model # KUDI24SEWH1 Serial # FF2307571 lately over the last year or so it has been getting progressively more noisy (sort of a low growling type noise) and approximately 2 or 3 months ago it began making an intermittent screeching or squealing noise which is very loud and irritating. It used to only do it on occasion, but now it seems to do it every time it is run and sometimes will continue on almost thru the entire cycle however it seems to go away while draining. I am wondering if it is worth getting it looked at and repaired and what could be causing the problem. I have not noticed any leaks or other issues other than the noise. It still functions normally and there has been no change in washing performance.(unless you count crappy detergent which seems to be everywhere these days LOL) I purchased the unit in 1997 and it has been used every day sometimes several times a day. I do have a back up unit and I was considering just pulling the Kitchenaid and installing the new unit but I really do like the Kitchenaid. So if you all could lend a helping hand and offer some advice w/o me having to pay a repairman 80 to 100 bucks for a service call just to find out its days are numbered and not worth repairing it would be greatly appreciated.My wife thinks I am nuts and wants to just use it till it dies. Sorry to ramble on and be so lengthy. I look forward to hearing from your members and your assistance is greatly appreciated.
ball bearing?
the description sounds like a ball bearing going bad,possibly
from leaky seal getting water into it-older KA,at least my
1973,had ball bearing motors-don't know about later ones,
most other brands are sleeve bearing motors. If motor can
be disassembled,changing the bearings is usually easy with
the right tools.
DIG DEEPER!
Your dishwasher was the first to use the Whirlpool power module pump in it and the noise you are hearing is probably something that has gotten into the pump and is stuck in the grinding chamber or is being pumped around but is too big to pass thru to the drain. Since the motor reverses to drain, the reverse water motion sends it away from whatever it is hitting and therefore the silence during draining as you described. It is not difficult to disassemble the pump to where you can see this piece of debris. Just remove the wash arm and then remove the he screen that covers the soil chamber. Then work your way down and you should find the offending item.
Refer to the link attached for the parts breakdown so you have something to look at as a guide to what you will be taking apart. It should be on page 11 of the PDF. I think you will find what is making the noise. It may surprise you to see what it is. I have removed, pits, broken glass, screws and washers not to mention sticks and toothpicks and pits from fruits.
Hope this helps
Let us know how you make out!
Steve
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair Part List - 4172115.pdf
Caution!
I have had this happen before. Broken glass was the problem and damaged the impeller. Be careful not to CUT yourself when digging deep!
Jim
