Hold The Phone! Westinghouse Spacemates
80s White Westinghouse Space Mates
These are worth closer to $50 than $450, the machines are not bolted together correctly and these washers usually need a lot of work, even if it works when you get it, it soon will need a good going over. Still a cool US FL washer.
John is right!
on many levels these machines are NOT used lightly and ready to go....
the door boot alone is not in place, the top panel of the dryer is missing, and the front panel of the washer is not attached correctly, and as John mentioned the dryer is not attached correctly, plus it gets me how filthy these machines are, look at that non see thru window alone, and yet they have the nerve to ask that kind of price...
someone has a bid in already, hope they know what their in for....this set will require more than a good going over, a major rehaul...
I would request to see them work before taking them, that is if they "work fine" as stated!....we have seen this all to many times, this person doesn't even try to clean them up to hide that theres any issues...
