I forgot to add : Buy a UPS !
The biggest issue is actually loss of local power in your own home. In urban areas this is (hopefully) a very rare event, but in rural areas if you've overhead lines it can happen during high winds.
In general cable, FTTC, FTTH and cellular services do have at least a few hours backup using packs of batteries in the local cabinets or even sometimes natural-gas powered generators. However, if you need a device powered in your own house to access these like a 'router' (home gateway) with an ATA to provide your phone service, or if you can't charge your mobile phone they're not much use.
You can buy a small UPS to keep your networking equipment alive during a power outage. They're not that expensive and they can keep things up for a few hours (especially low power devices like routers).
Likewise, you can charge your mobile from a UPS without any issues.
If you're in a rural area that suffers from frequent power outages, it might even be worth investing in a backup generator. A small one will be plenty to keep the lights on, the fridge running and enough power to charge your mobile and keep your network gear up.
You don't need enough power to run the stove and the tumble dryer, but just enough to tide you over should there be a major storm. Also, bear in mind that in most homes the heating system requires power to run control systems, pumps, ignitors etc even if it's not using electricity to heat your home. So, if you're in a remote, cold place, you probably should have one.
A lot of rural homes here have moved over to using microwave links instead of landlines.
Also, in rural areas, if you're hit by a storm it's likely you'll lose phone service too even on POTS lines if they're overhead. So, it's always handy to have a backup
@Laundress:
When you dial "10" (Operator) here you get : dooo dee dooo.. We're sorry the number you have dialled has not been recognised!
There's no longer any type of operator service, if you want help, you call your supplier's helpline and speak to the evil robot who will eventually (if you answer all of its riddles correctly) connect you directly to a customer frustration specialist.
I've found the best way to get their attention is to go onto their help forums and make a public nuisance of yourself
[this post was last edited: 8/7/2014-10:30]
@Laundress:
