Homemade detergent for a front load Speed Queen
julianweber
Active member
Oct 14, 2012
33
Rome, GA
I have just ordered a new Speed Queen AFN50F washer, and it will be our first front load washer. My wife likes to make her own laundry detergent like the directions posted on the link below.
What settings or changes to the wash cycle would be optimal for this type of soap? ie. Water level, wash temp, rinse temp, pre-soak, wash length, number of rinses etc.
Also, if anyone has there own formula for detergent that they like better for certain stains or soils, I would like to hear those as well.
There Are Several Threads Here In the Group About That *Home
Long story short do not bother.
First the recipe uses far to little soap to get the job done. Next the entire thing does not begin to match the cleaning power of a good modern detergent like Tide, especially for stain removal.
Pure soap for laundry day went out of fashion for many reasons which again you can search about here in the group. Without a vast supply of hot water for both washes and several rinses using pure soap is going to leavy your laundry dull, dingy and what is more gunk up your new washing machine.
SQ states in it's owner's manuals (or at least it used to) that one could use regular detergent in their washers, long as dosage was 1/4 cup or less. What you want to avoid is froth (suds), that is because the excess of which not only hampers wash action in front loaders, but can also can lead to machine problems like early bearing failure.
Cannot speak to where you live, but Tide is frequently on sale around here. There are also many decent choices for "HE" detergents. What you'll have to do is experiement with dosages until you find the right balance between amount and clean laundry. Usually anywhere from two tablespoons (don't look at me like that) to 1/3 is about right for most machines especially as most detergents are now more concentrated.
With a brand new washer it is important to start things off right. It will save you no end of trouble down the line.
Launderess
Interesting bit of info there. What would be the correct concentrations of soap etc for proper cleaning. Do you happen to know what the makeup of a modern detergent is?
If you want cheap detergent, try FOCA. It's a Mexican detergent that is relatively low sudsing and cleans very well. A nice size bag that will last you at least 6-8 months is generally available at WalMart for $3.27 a bag. And that's really cheaper than the home made detergent is.
I have used it in front loading machines and it does keep the suds down and rinses out really well while doing a good job of cleaning. It even smells nice too.
Correct Dosage Of Real Soap For Laundry
Will vary by several factors up to and including water hardess, soil amount of wash load, and water temperature.
Best method is to use enough soap so there is a "lively" amount of deep creamy froth during the wash. This can vary from one to two inches deep when tub washing or in a top loader with a central beater, to nearly one third to one half way up the window in front loaders.
As you can see the amount of froth required for good cleaning in a front loading washer with soap isn't really practical. That amount of froth will form a cushion which leads to poor laundering performance. Then there is also the fact it could cause suds lock and or otherwise damage your washer.
Have tons of vintage laundry soaps in my "stash" (Ivory Snow, Kirkman's Borax, P&G White Laundry Soap, Lux Flakes, etc..) and do love experimenting with various brews, but wouldn't want to go back to using only soap on wash day.
Word of warning, use of soap for laundry requires lots of hot and *soft* water. If you don't have either especially the latter shouldn't mess around with the stuff in your washing machine. After awhile your nice new machine will start to get a build-up of gunk inside from soap scum deposits.
juilianweber
Is there a particular reason your wife is using the homemade stuff?
She may have her reasons?
Happy wife... happy life!
Depending on her reasons, or if she insists on this, I may be able to help her by suggesting some changes to the percentages of her three ingredients, and or substituting with another, to make what she's using more effective.
The Fels Naptha isn't exactly a "pure soap" per se, as there are some ingredients already in the bar that are "supposed" make it.. sort of a built soap.
If her reason is, to be more economical, then I would agree with what's been pointed out up thread.
If you can get your hands on some STPP, and add it to the washer BEFORE the clothes, water and homemade laundry detergent, then you MIGHT be able to get away with it.
I've used it in combination with grated Ivory hand soap, with relatively good results. However hot water is a must in order to get the soap to dissolve. And it IS difficult to find a modern front loader (or any modern washer) that will allow one to select hot rinses. So rinsing out soap residue/scum may be a bit dicey in a modern machine.
Comcentration
Chris, I have a Spanish Fagor front loader machine and use regularly Ariel (made in Argentina) and put 2 or 4 tablespoons of powder detergent and works perfectly. If I want to whiten clothes I add non chlorine bleach and wash in 40o C.. That's enough. If I use liquid Ariel, also Argentinian, I probably use about 2 tablespoons sometimes only 1. I don't need more than that. My machine uses SO little water for cottons that you can't see the water level through the window, but the results are outstanding. My two cents.
Apart from this, I wonder WHY some individuals refuse to fill in the questions and data of their profiles. What are they afraid of? I think this is a safe place with certain (good) surveillance from our webmaster which makes it a safe place where we can be quite sincere referring our feelings and thoughts. I don't want to offend anyone, but I just can't understand their reasons. My regards to all, Gus
Mr. Weber---
PLEASE listen to Laundress! Please.
The Speed Queen is the best washer made in the United States now, and we all want you to have a good experience with it.
I agree with the suggestion of Sears Ultra Plus detergent. Ten cents a load! It is often on sale, and price per use goes as low as five cents a load. That homemade blend isn't any cheaper! You'll want the orange box formula.
Lawrence/Maytagbear
We still don't know
the wife's reasons for her preference to "The Homemade mix"
So we can't help til we know why?
Laundress has pointed out that there is not enough soap in the mix. She is absolutely correct!
When you do the math, the mixture calls for 10 cups of water along with the 5.5 ounces of Fels. This is all supposed to do 64 loads of laundry! The 5.5 ounces divided by three, equals 1.83 ounce per BATCH! Or to make this easier to understand in grams, that is only .84 grams per LOAD of laundry. Not even one full gram!
I could go on with the rest of the math for the other ingredients if you want, but the point is, there is NOT enough to do anything to the fabric, or to the machine at this dilution.
If your wife insists on using this, then there is a much better math formula she could use!
The STPP that sudsmaster suggested incorporating to the mix, would be a huge step in making this preform much better, provided that you have at least a warm option for rinsing
If you want a better math formula, with some additions (STPP, and maybe some OxyClean) I'll be happy to help.
@chris74
Should have been more clear.
One to two tablespoons applies to most European detergents in my stash (Persil Megaperls (Henkel),and so forth).
Because the water in the United States, especially in my local area is much softer than what is quite often found in the UK or EU areas one needs less detergent.
Of course it all depends upon load size and soil levels. For instance more than about 1-2 TS of French Ariel "Excell" gel (Alpine Fresh) will cause tons of froth and take ages to rinse.
The Amercian detergents such as Tide "HE" in both powder and liquid have a very fine line between proper dosage and too much. Once you reach the latter it takes more rinsing the usual to get the stuff out.
I agree with everyone steering you toward a good HE (high efficiency) detergent for your new Speed Queen.
I bought homemade soap online and used it in a top-loader, where I could get a warm rinse. If you follow a warm or hot wash with a cold rinse (as you'll have to with your new washer), soap scum will build up quickly "behind the scenes" in your washer.
HE detergents are formulated for use in new washers which use very little water. Unless you drastically reduce the amount of standard detergent/soap used, you'll not be pleased with rinsing results.
And heed the warnings about early bearing failure due to oversudsing.
Hope you love your new front-loader! I am a die-hard front-load advocate, and I find that even the new machines which use very little water can produce excellent results. I use powdered Tide HE Vivid (color safe bleach) and Persil Bio powder from the UK. Both give excellent results in my 2010 Frigidaire front-loader. Be prepared for the shock of seeing no water in the tub! Clothes are saturated with highly-concentrated detergent, but there will be no water splashing about.
Wife's Reasons
Thanks everyone for all the information and advice. I love all the experience available on this site!
Stan, the reasons for using the homemade detergent is due to allergens. Supposedly the Borax will kill dust mites (something that causes us allergy's). We are also concerned with the various carcinogens in commercial detergents. I would absolutely like to know what other recipes / concentrations you would suggest.
Sudsmaster, What is STPP and how does it affect the outcome of the wash.
Frigilux, I am looking at using a thermostatic mixing valve on the cold water inlet to the washer, thus limiting the cold water rinse to a minimum temperature. In other words what the machine calls a cold water rinse would become a warm water rinse.
Julian
Whilst I can't for a minute suggest that the chemicals used in detergents are not harmful, they have all been approved for use - most of them globally.
If dustmites are your worry, I'd be focusing on house cleaning more than trying to kill them once they are there as they live off the dander that we, and our pets, create and it is their faeces that causes the issues.
The best thing you can do to get rid of them is to:
- remove your carpets
- air your house out regularly
- vacuum regularly with a good cleaner (twice weekly)
- 'damp' dust
- dry washing outside.
Using a home made detergent isn't going to fix the problem and it WILL, without any doubt at all, lead to issues with your rather expensive new washing machine, your clothes WILL become manky and you WILL end up cursing.
The people on here have, cumulatively, many 100's of years experience with machines and detergents, not to mention the 'soap' concoction you mention above. A good detergent, synthetic or otherwise, will run rings around anything you care to make at home and be better for your machine.
If chemical concern is an issue, buy one of the 'green' options, but I'll lay down a challenge. After using your home option for 12 months, do 2 things. Get the best detergent you can and do a HOT, empty wash in your machine and then look at the wash water as it drains. It should be milky if your machine is clean inside, but pound to a penny says it will be grey at best indicating a buildup of gunk....
...next, take a load of supposedly clean sheets that you've used regularly and repeat the procedure.
My guess is you'll never use home made stuff again.
Wouldn't "All Free" powder or "All Free and Clear" liquid be a better substitute over the homemade stuff? I keep seeing ads about them being recommended by various dermatologists over Tide Free or any of the others in that category.
Also, if worse comes to worse, I'm sure you can add a tablespoon or whatever the recommended amount on the package is of Borax to your wash load.
It's always fun to see home-brew soap recipes.
My Aunt Alice used to make soap with rendered pork fat, lye and a couple other secret ingredients. She made it outside in a cauldron over an open fire - probably because unleashing that much Sodium Hydroxide indoors would have sent everyone to the hospital.
Aunt Alice's soap was a great stain pre-treat formula, though - she passed 30+ years ago and there are still a few closely-guarded sticks floating around our family.
I sure wouldn't use it in a washing machine, though.
