Hoover 155 (D6028) Dryer Overhaul Pt 2
The motor with both belts installed. The pressure roller can be seen at the other end of the motor applying tension to keep the drum belt tight.
The drum belt was new at the last overhaul and is still in perfect condition. The fan belt was replaced a few years ago and is in good condition.
Was this message on Hoover dryers in the UK?
I obtained a new door seal from the supplier in SA, but it must be for dryers with glass in the door. The seal is not tall enough to reach my door and seal it. As the doors with glass have a raised section to retain the glass (the same pressing as the washers), the seal must be for them. My seal is not too bad luckily.[this post was last edited: 11/27/2013-00:22]
Manufactured in December 1978.
I guess the serial number of 73 means this was the 73rd 155 made that month. This batch probably fitted in between morning tea and lunch. Hehe.
At risk of boring you further, I'll add some further images to this thread rather than create another.
I decided to treat the 455 to a new control panel which has been in my possession for many years. It's like the old joke - I'd better not use the last one in case I need it later. Hehe.
The control panels on these machines are retained by diabolical pressed steel nuts. The (soft) plastic posts also break off very easily.
When you try to undo them, they just keep rotating on the stripped section of the plastic post. The panel needs to be pulled outward when unscrewing them.
Once again, the mess is the fish oil paint I used on everything. The only slight bit of real rust is at the centre top of the detergent dispenser aperture. This was quickly cured with Kurust.
This part of the timer control knob is prone to cracking. After replacing this part for the third time, I found that a single wrap of soft steel wire cures the problem completely.
The shop in South Africa I mentioned earlier had what I thought was the correct one of these for my machine. When it arrived, it was found to be for models where the indicator line is at the 12 o'clock position. Mine is at the 10 o'clock position so the numbers don't line up.
They also have these for sale with letters, rather then numbers, for other models.[this post was last edited: 11/27/2013-00:28]
