Hoover 155 (D6028) Dryer Overhaul Pt 2
crouzet951
Jul 12, 2013
278
Hi to all again.
I did get the model number correct this time. Sorry about that.
This is the second part of the overhaul - fitting parts and reassembling.
Regards
John
One of the motor end plates. The rotor bearings are sintered bronze which soak up oil for lubrication. Here I've blocked the lower end with plasticine and filled the bush with oil. These were left overnight.
This was done at the last overhaul, and as described in part 1, there is almost no wear of the bushes or rotor shaft.
The cleaned up windings, rotor, and one of the endplates, ready to reassemble.
End thrust of the rotor shaft is controlled by washers at the fan end of the motor. They can be seen on the shaft.
Minor disaster 2.
The new fan bushing housing has not been machined properly. I didn't think this would cause any trouble, but the hole in the fan housing that this passes through is quite a tight fit.
The only thing I had to hand to remove this was a fret saw. It did the trick, but it wasn't a pretty sight afterward. No photo was taken. Hehe.
Once again, the bushings needed to soak up oil overnight. There is some fibre material between the inner and outer bushes which act as a reservoir.
The new fan shaft is next to it.
The old and new shafts. There was already slight wear on the shaft and the bushes when the dryer was overhauled in 1991, and the shaft still looks much the same.
This is the new fan bearing assembly mounted in the fan housing. Rather then using aluminium rivets again, I used 3mm stainless steel (ss) set screws with washers and ss nyloc nuts.
The fan is very nice cleaned up.
Just thinking, that it would make a great clock dial (perfect with 12 blades for the hours) for the Hoover enthusiast who has everything. Hehe.
All ready to go. The felt seal is original and is in very good condition, especially after a good vacuum.
At this point I decided to install the thermostat on the fan housing while it was out. It is retained by a rubber grommet that can be tricky to install.
The cleaned up cabinet ready to accept the drum. I removed the broken element insulator and glued it back together with Chemical Metal. I thought it was worth the risk.
If it comes apart again now that the machine is back together, it can't do any damage.
If anyone has a spare element insulator for these machines, please let me know as I'd like to buy one as a spare.
As mentioned earlier, the cabinet has to be spread slightly to get the drum back in. Towels were used to protect the paint on the cabinet.
The 455 is washing a load of towels as a first test of the dryer.
Ready for the fan housing. The rear drum bearing rotates at low speed so I used grease for lubrication.
The drum housing is retained by four screws with these large strengtheners. These screws need to be tight, and unfortunately the original screws strip very easily. They were replaced with ss screws as pictured.
These clever multiple holes allow the fan housing to be moved in and out slightly, to adjust the end float of the drum.
